Does AGSGDBSyncTask syncGeodatabase block?
4538
7
10-07-2014 11:30 AM
KristofferStenersen
Hello world,
In the OfflineFeatureEditingSample, the syncGeodatabase method is called from the main thread (IBAction from Storyboard).
In our app, we have a fairly large dataset to sync (12 tables with some 100k´s of features), and we see that, as the size of the dataset increase, the UI blocks for longer periods of time. At this point, the call seem to block about 15 seconds. This is a critical issue for us, as the app triggers sync at regular intervals. With smaller datasets, this has not been an issue with the current code.
We´ve tried posting the operation on a background thread (dispatch_async/performSelectorInBackgorund), but then the we do not get status or completion callbacks.
Please advice:)
Kristoffer
DavidLednik
Occasional Contributor II
Hi Kristoffer,
Which version of SDK are you using?
KristofferStenersen
Hi David,
I´ve just verified that the issue persist on 10.2.4.
Kristoffer
DavidLednik
Hi Kristoffer,
let me check on my side. I don't think this call should be blocking the UI.
I'll try to find a large dataset for the test.
Regards,
David
KristofferStenersen
Hi, Thanks for looking into this.
A (perhaps) related issue: We also experience, that on this large offline gdb, the first edit is very slow - the [agsgdbfeaturetable save:agsgdbfeature error] takes about 5-15 seconds. The following edits are fast.
On the edit operations though, we´re able to run the operation in background threads, to not block ui. But on the synchronization operation we do not get callbacks running on background threads; ui blocks.
DiveshGoyal
This will be fixed with the upcoming 10.2.5 release
KristofferStenersen
Thanks Divesh. Can´t wait to get it:)
KristofferStenersen
Hi, we´re still seeing a delay on 10.2.6. It´s better though: Down from 60 to about 10s in my current setup.
