here the thing-
in the same layer, I have POINT_X, POINT_Y and POINT_X_1, POINT_Y_1, as decimal degrees.
I´m trying to find the linear distance in meters from the 2 points.
I´m trying to get it with pyhton, using the below code, but I get always the same syntax error
Any help appreciated
Joao
pre-logic code
ef Haversine(Lat0, Lat1, Lon0, Lon1):
[INDENT]dlat = Lat0 - Lat1
dlon = Lon0 - Lon1
a = (math.sin(math.radians(dlat)/2 )*math.sin(math.radians(dlat)/2 )) + math.cos(math.radians(Lat1) )*math.cos(math.radians( Lat0 ) )*(math.sin(math.radians(dlon)/2 )*math.sin(math.radians(dlon)/2 ))
c = 2*math.atan2( math.sqrt(a ),math.sqrt(1-a ))
H = c * 6371
return H
[/INDENT]
Code:
Haversine( !POINT_Y! , !POINT_Y_1! , !POINT_X! , !POINT_X_1! )
Solved! Go to Solution.
At the moment this process is comparing apples and oranges and it will give incorrect results.
This said, the process needed is to build in a reproject function to take the coordinates from Geographic Coordinates (decimal degrees) into Map units (meters).
#Todo Get distance between 2 point
Step 1: Build up representation of 1st point in memory as PointGeometry Object
Step 2; Reproject point in map units
Step 3: Build up representation of 2nd point in memory as PointGeometryObject
Step 4: Reproject this into Map Units
Step 5: Compare the 2 points using Pythagoras Formula.
Attached is a function to perform the Reproject using the arcpy module
#projectSR
def projectSR (pt, sr): #sr = spatial reference, pt is geometry in memory
#constantts
gcs = arcpy.SpatialReference(2193) #2193 = factory code for NZ Transverse Mercator
gt = 'NZGD_2000_To_WGS_1984_1' #geographic transformation, if application
coords = []
ptgeom = arcpy.PointGeometry(pt, nztm).projectAs(gcs, gt)
coords.insert(0,(ptgeom.centroid.X))
coords.insert(1,(ptgeom.centroid.Y))
del ptgeom
return coords
Call projectSR to get the coordinates in map units meters and then you'll be able to use the Pythagoras theorem.
Susan
#projectSR
#constantts
coords = []
del ptgeom
return coords
Susan
If you still want to use Haversine, there are many examples on the web in python, for example
