How to set up geoprocessing widget with uncompiled file?
3493
10-09-2014 02:57 PM
LeiZhou1
I download the source code of Flex Viewer 3.6 and input it to Flash builder.  After reading the following post from ESRI, I realize the config file of GeoprocessingWidget.xml does not even exist, then how do we set the widget? Thanks!
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Geoprocessing_widget_tags/01m30...
The set up codes in main config.xml is as the following:
<widget label="Geoprocessing" left="10" top="400"
                icon="assets/images/GeoprocessingTool48.png"
                config="widgets/Geoprocessing/GeoprocessingWidget.xml"
                url="widgets/Geoprocessing/GeoprocessingWidget.swf"/>
RobertScheitlin__GISP
Lei,
  Most people either just create the XML themselves or use App Builder to configure the widget.
Here is a sample:
<?xml version="1.0"?>
<configuration label="Drive time analysis">
   <taskurl>http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Network/ESRI_DriveTime_US/GPServer/Create...</taskurl>
   <helpurl>http://sampleserver1.arcgisonline.com/arcgisoutput/Network_ESRI_DriveTime_US/CreateDriveTimePolygons...</helpurl>
   <inputparams>
   <param name="Input_Location"
   geometrytype="point"
   label="Start location"
   required="true"
   type="featurerecordset"
   visible="true">
   <simplerenderer>
   <simplemarkersymbol color="0xBEEFEE" size="15">
   <outline width="2" color="0x00AADD"/>
   </simplemarkersymbol>
   </simplerenderer>
   </param>
   <param name="Drive_Times"
   defaultvalue="5 10 15"
   label="Drive times"
   required="false"
   type="string"
   visible="false"/>
   </inputparams>
   <outputparams>
   <param name="Output_Drive_Time_Polygons"
   geometrytype="polygon"
   label="Output Drive Time Polygons"
   required="true"
   visible="true">
   <popup>
   <title>{Name}</title>
   <fields>
   <field name="FromBreak"
   alias="From Break"
   visible="true"/>
   <field name="ToBreak"
   alias="To Break"
   visible="true"/>
   </fields>
   </popup>
   <uniquevaluerenderer field="ToBreak">
   <simplefillsymbol alpha="0.5" color="0xFF00FF">
   <outline color="0x000000"/>
   </simplefillsymbol>
   <uniquevalueinfo value="5">
   <simplefillsymbol color="0xFF0000">
   </simplefillsymbol>
   </uniquevalueinfo>
   <uniquevalueinfo value="10">
   <simplefillsymbol color="0x00FF00">
   </simplefillsymbol>
   </uniquevalueinfo>
   <uniquevalueinfo value="15">
   <simplefillsymbol color="0x0000FF">
   </simplefillsymbol>
   </uniquevalueinfo>
   </uniquevaluerenderer>
   </param>
   </outputparams>
   <layerorder>Input_Location,Output_Drive_Time_Polygons</layerorder>
</configuration>
  See Geoprocessing widget tag reference at
  http://links.esri.com/geoprocessingwidget
Lei,
Here is a sample:
   <inputparams>
   required="true"
   visible="true">
   <simplerenderer>
   </simplerenderer>
   </param>
   label="Drive times"
   required="false"
   type="string"
   visible="false"/>
   </inputparams>
   <outputparams>
   required="true"
   visible="true">
   <popup>
   <fields>
   alias="From Break"
   visible="true"/>
   alias="To Break"
   visible="true"/>
   </fields>
   </popup>
   </simplefillsymbol>
   </simplefillsymbol>
   </uniquevalueinfo>
   </simplefillsymbol>
   </uniquevalueinfo>
   </simplefillsymbol>
   </uniquevalueinfo>
   </param>
   </outputparams>
</configuration>
LeiZhou1
Thanks a lot!
