arcpy change data frame coordinate system
8466
7
08-25-2010 01:02 PM
RyanKelley
I have a tool that allows a user to zoom to a township/range for anywhere in the Western US... My data frame is in GCS NAD1983, but depending on where the user zooms, I want the data frame to reproject to a specific UTM Zone depending on where the township/range is located.
I've played with the spatialReference class, but no luck yet.
Any ideas?
Thank you in advance!!
RyanKelley
I guess I posted my question too soon...
prjFile = prjPath + "/" + "NAD 1983 UTM Zone 10N.prj"
sr = arcpy.SpatialReference(prjFile)
for DF in MAP.ListDataFrames(MXD):
    DF.spatialReference = sr
ScottOatley
I'm getting a runtime error when trying this.
sr = arcpy.SpatialReference(prjFile)  <--- runtime error 999999
I'm just entering this one line at a time in the python command line window as follows:
import arcpy
prjPath = "C:/Program Files .../"
prjFile = prjPath + "NAD 1983 UTM Zone 10N.prj"
mxd = arcpy.mapping.MapDocument("CURRENT")
df = arcpy.mapping.ListDataFrames(mxd)[0]
Then get the runtime error.
Am I missing something, or does this not work with "CURRENT", or by entering one line at a time?
Scott
ScottOatley
This is the path created by our Arc install:
prjPath = "C:/Program Files(x86)/ArcGIS/Desktop10.0/Coordinate Systems/Projected Coordinate Systems/UTM/NAD 1983/"
The last statement causes a run-time error. I recreated that path as:
"C:/My Program Files(x86)/ArcGIS/Desktop10.0/Coordinate Systems/Projected Coordinate Systems/UTM/NAD 1983/"
and it works fine. The only difference I can think of is that the original "Program Files(x86)" folder is read-only where my "My Program Files(x86)" folder is read-write.
Any ideas?
Scott
RyanKelley
I get this error from time to time for a variety of tasks within a script... but I only seem to get it when running something in the ArcPy window in ArcMap.
Usually I just re-start ArcMap and everything is totally fine.  Why this happens... ???
ScottOatley
Any ideas?
Scott
Figured this out. I missed a space in the original path. It's between "Files" and "(x86)."
Scott
MarkJames
import arcpy
Scott
Could you explain a little further how this works? I haven't been able to figure out what I am missing to get this to work.
JeffBarrette
The issues identified earlier in this post were paths with typos.  It is extremely important to get the paths correct.
As a simple test, I browsed to a PRJ file in the ArcGIS coordinate systems folder.  Here is a trick.  Hold down the SHIFT key and right-click on a file.  Then select "Copy as Path" from the context menu.
Then I opened a new map document and the Python window.  I typed:
sr = arcpy.SpatialReference(r  then I clicked Ctrl-V)  the result looked like
sr = arcpy.SpatialReference(r"C:\Program Files (x86)\ArcGIS\Desktop10.0\Coordinate Systems\Projected Coordinate Systems\UTM\NAD 1983\NAD 1983 UTM Zone 10N.prj")
mxd = arcpy.mapping.MapDocument("current")
df.spatialReference = sr
If you are still having complications, please post your code.
