Good morning from Norway!
I assume most of you who participates in this group is quite excited and looking forward to the release of 10.3 and of course the caching services for 3D-features.
Most of you have probably seen the video/presentation where publishing 3D content to Portal is shown. It looks really cool and I think this is one of the things that we are missing in 3D-GIS.
I am so lucky that I got to test the pre-release of 10.3 and ArcGIS Pro. So my question: To be able to publish a 3D-service to my portal it says in the documentation: "All scene services begin inside ArcGIS Pro where you author a 3D scene. When you've finished authoring and are ready to publish, select the desired 3D layers in the Contents pane, right-click, and choose Share As Web Layer" This is also shown in the presentation from UC2014:
Here we see that when you right-click the layers under 3D-layers you got the option Share as web layer. Here is what happening when i'm doing the same thing:
As you see the option is grayed out. I am trying to publish a multipatch, is this the right format? because it's realy looks like Gert and the crew are publishing multipatches in the presentation (first screen-dump).
I have done this steps:
You'll need to install and set up the following ArcGIS components in order to create a scene service and share it as a web scene:
- ArcGIS Pro
- ArcGIS for Server
- ArcGIS Data Store
- Portal for ArcGIS
Once the components are installed, you'll need to configure ArcGIS Data Store with your server, federate the server with your portal, and designate ArcGIS Server as the hosting server.
Some who got a clue?
Thanks!
Regards
Jørn
