How do you get Python 3.4 to see ArcGIS Pro arcpy?
12043
11
10-30-2014 08:07 AM
curtvprice
MVP Esteemed Contributor
I am trying to access ArcGIS Pro's flavor of arcpy. I installed the 3.4.0 distributed with Pro (beta 5, and pr), open IDLE fine, but... arcpy is not automatically in the sys.path.
Is there a .pth file I am missing?
Python 3.4.1 (v3.4.1:c0e311e010fc, May 18 2014, 10:45:13) [MSC v.1600 64 bit (AMD64)] on win32
Type "copyright", "credits" or "license()" for more information.
>>> import arcpy
  File "<pyshell#0>", line 1, in <module>
    import arcpy
ImportError: No module named 'arcpy'
>>> import sys
>>> print("\n".join(sys.path))
C:\Windows\system32
C:\Python34\Lib\idlelib
C:\Python34\python34.zip
C:\Python34\DLLs
C:\Python34\lib
C:\Python34
C:\Python34\lib\site-packages
Tags (3)
BruceHarold
Hi
C:\Python34\Lib\site-packages\pro.pth
C:\Program Files\ArcGIS Pro\bin
C:\Program Files\ArcGIS Pro\Resources\ArcPy
C:\Program Files\ArcGIS Pro\Resources\ArcToolBox\Scripts
C:\Program Files\ArcGIS Pro\bin\Python\Lib\site-packages
BruceHarold
Hi
BruceHarold
Also, to set IDLE as your script editor in Options>Geoprocessing set your script editor:
C:\Python34\Lib\idlelib\idle.bat
curtvprice
Thanks so much Bruce, I'll try it as soon as I get a chance.
I do not have access to my Python34 folder (locked down installs) so I suppose I can do the same thing with the PYTHONPATH env variable.
Does 3.4 support an alternate user location for the .pth file?
curtvprice
This list of paths worked great.
I have installed Pro single-user as I do not have admin access to this machine so cannot edit the Python34 folder - so I solve the problem using the PYTHONPATH environment variable. I launch python here from its own batfile so I don't confuse my Desktop environment, which has a PYTHONPATH set up to access my Desktop 10x scripts.
py34.bat
:: start python 3.4 with ArcGIS Pro arcpy available
@echo off
set AGPHOME=C:\Users\cprice\AppData\Local\Programs\ArcGIS Pro
set PYTHONPATH=^
%AGPHOME%\bin;^
%AGPHOME%\Resources\ArcPy;^
%AGPHOME%\Resources\ArcToolBox\Scripts;^
%AGPHOME%\bin\Python\Lib\site-packages;^
C:\Python34\python.exe %1 %2 %3 %4 %5
This seems to work fine:
>>> import arcpy
>>> arcpy.GetInstallInfo()
{'Version': '1.0', 'InstallTime': '8:45:39', 'SPBuild': 'N/A', 'ProductName': 'ArcGISPro', 'BuildNumber': '1472', 'InstallType': 'N/A', 'InstallDate': '10/30/2014', 'SourceDir': 'F:\\EsriMedia\\ArcGISPro_PreRelease\\ArcGISPro\\', 'SPNumber': 'N/A', 'Installer': 'cprice', 'InstallDir': 'c:\\users\\cprice\\appdata\\local\\programs\\arcgis pro\\'}
JanCibulka
I tried this, but after "import arcpy" windows throws "python.exe has stopped working" and whole script goes down. I admit, I am using Anaconda distribution, specifically Python 3.4 64bit. On Anaconda 2.7 with arcpy from 10.3 everything working fine.
Edit: Windows logging points on "\ArcGIS Pro\bin\AGOLHelper.dll"...
Edit 2: It's not Anaconda problem, it persists in Python 3.4, downloaded from Esri page, so it's apparently bug connected to latest ArcGIS Pro release.
Thanks.
curtvprice
I suggest taking a careful look at the sys.path to make sure there isn't a problem.
Also: have you turned on the checkbox from ArcGIS Pro to allow offline access to your Pro license?
JanCibulka
It was the offline access to Pro license, after enabling it arcpy imports without problems.
Thanks very much.
curtvprice
That's kind of weak.  Hey Esri GP gear heads - import arcpy should do this check and handle it!
Luke_Pinner
MVP Regular Contributor
The above didn't work for me with 1.1 (first time playing with Pro today in a training course).
The following worked for me in a pth file:
C:\Program Files\ArcGIS\Pro\bin
C:\Program Files\ArcGIS\Pro\Resources\ArcPy
C:\Program Files\ArcGIS\Pro\Resources\ArcToolBox\Scripts
C:\Program Files\ArcGIS\Pro\bin\Python\Lib\site-packages
