Problem of slope average in crest zone
2927
11-06-2014 02:59 AM
YannickCREST
Hi everybody!
I delimited catchments on raster map of the Pyrenees, constructed from LiDAR data.
I want to obtain slope average of these catchments. So I use 3D Analyst tool to add Z information.
The average slope is higher than 90° and is even higher than 500° for some catchments.
This problem is derived from the Z data of the crest zone, probably because of the steepness of these crests.
Does someone know how to resolve this problem and to obtain more "classical" average slope?
PS: when I contruct slope map from the raster, there is no problem and all the slope values are between 0° and 90°, even in the crest zone...
DanPatterson_Retired
You didn't set it to calculate slope in degrees but in percent
YannickCREST
How is it possible to set it in degrees using "3D Analyst tool Add Z information"?
by the wildest chance are your coordinates in decimal degrees and your z values in meters?
YannickCREST
I don't know. Where can I find these informations?
It's a raster from the spanish IGN
In the layer properties menu, we can read:
"Spatial reference : ETRS 1989 UTM Zone 31N"
"Linear unit : meter (1.00000)"
"Angular unit : degrees (0.174...)"
