I can create a multiversion view and then use 'set_current_version' to change to the version that I require. And this is all good if I am accessing ArcSDE programmatically or through the interface presented to me by SQL 2008 Manager. But how can I set up a view that can be accessed via a remote connection such as through a 'linked table' in Microsoft Access? I need to be able to serve the view in a standard (think ODBC connection) way to the client that will be using the view.
Because the set_current_version stored procedure must be executed before the correct version can be seen in the multiversion view, it appears to be difficult to present the view as an easy-to-use ODBC connection that can be consumed by a remote client. Any help on how to get around this problem would be very much appreciated.
Regards,
Dion Liddell.
