ArcScene extent vanishes
3638
11-29-2014 11:45 AM
FaithWebster
I am doing the Esri 3D Visulazation Techniques web course, and just finished symblizing the watch towers. After using the fly tool to get a closer look, my scene vanished. When I hit 'view full extent' the scene flashes and disapears again. I get the same results when I zoom to a layer. I trying adding the vegitation layer to see if the problem would self correct but no luck. I have not saved my work, and I am not sure how to fix this problem. Can anyone please offer some suggestions on how to fix it, and insight into what went wrong?
Thank you,
Faith
DanPatterson_Retired
hmmmm did you try hitting ESC ?
FaithWebster
I bit the bullet saved, and exited and reloaded. It worked.
Thank you
