ServerFolder - how to use it
5620
6
12-05-2014 09:40 AM
nita14
Occasional Contributor III
Dear all,
I would like to access the results of my local geoprocessing service using ArcGIS Runtime for Java. I found ServerFolder class to access server folders. The constructor is ServerFolder(String name). Does anybody know what is a name? What should I pass there? I belived it should be jobid (which is also a folder on server) or gpservice url, but it does not work. Can you give my any example how to use it?
Thank you in advance,
Best Regards,
Adam
nita14
Resolved in Runtime 100.0.0
EricBader
Hi Adam,
You shouldn't have to use the ServerFolder class to retrieve the results of your GP Task.
Here is a good reference for how to execute the GP Task and get the results of the task back in your application.
Run a geoprocessing task—ArcGIS Runtime SDK for Java | ArcGIS for Developers
I hope this helps!
LukeCatania
New Contributor III
I am looking for a way to access the results so I can copy them to another location specifically to copy features and raster data from the resulting temporary scratch.gdb to another GDB.  I thought the download method of this ServerFolder or ServerFile class would help as I have not found another way to do this yet.
nita14
Hi Eric,
    Suppose that my gpk file produces a GPRasterDataLayer as an output  and I do not use RMS to show the results - I have an issue with that. I would like to consume the result in my ArcGIS Runtime App. I can access the result using url, included in the json response. I do not want to use java net classes to download file which resides on my local machine. I would like to use ServerFolder class to access the output of my geoprocessing and add it as a RasterDataLayer to my application.
EricBader
Does this not do what you want?
ArcGISDynamicMapServiceLayer resultMapServiceLayer = new ArcGISDynamicMapServiceLayer(gp.getUrl(), jobResource); jMap.getLayers().add(resultMapServiceLayer);
nita14
Hi Eric,
  I have an issue when trying to run my gpk in RMS mode. I described it here Re: ArcGIS Runtime for Java 10.2.4 - com.esri.core.io.EsriServiceException:
Thank you in advance for help
nita14
