Hello...i have problems about using tool "Sun Shadow Volume" In ArcScene 10.1.
i use feature (shp) extruded 3D layer
then i use tool "Sun Shadow Volume" with data :
- Start date and time : 1/22/2015 6:00:00 AM
- End date and time : 1/22/2015 5:00:00 PM
- Iteration interval (optional) : 1
- Iteration unit (optional) : hours
but always it don't succeed..
Thank You.
Solved! Go to Solution.
Could anyone please share a small sample data to testing?
Could you please turn off background processing and run the tool again? any error message?
Hello....Mr Kishor Ghatage, i had uncheck background processing on geoprocessing option and run the tool again, but still appear the massage :
Start Time: Mon Jan 26 09:27:57 2015
ERROR 999999: Error executing function.
Failed to execute (SunShadowVolume).
Failed at Mon Jan 26 09:27:57 2015 (Elapsed Time: 0.00 seconds)
Hi, I try to uncheck the background processing on geoprocessing option but it still has the same error (999999).
And the result said that the table was not found and the sun shadow volume failed to execute.
Any other suggestion for solving the problems? Thanks a lot!!!!
Ying
Could you please let me know ArcGIS version ,SP level (e.g. ArcGIS 10 SP1) and OS (e.g. Windows 7) ?
Hi, I also got the same error result with you and do not know which part cause the problems.
I also get this message - my error is ERROR:999999: error executing function
I also get "The table was not found. [name of my table which has been created, but which is empty]
Hi All,
I have tested the behavior using 10.2.1 and it worked fine.
A. Try exporting your data from Shape file to Feature class if you are working with shape file or vice-versa. > > Run tool again
Also Try:
1. Take backup of your input
2. Run Check geometry tool
3. Run Repair Geometry tool
4. Run Sun shadow..
Hope this is helpful.
Kishor
Hi. Mr. Kishor Ghatage
Thanks for your responses.
i am using ArcGIS 10.1 Version and Windows 7 32-bit.
i had Run Check and repair geometry tool, and the teble result is empity = (feature no problem).
then i run again sun shadow tool but has not also been succeed. i use "multipatch feature"
thanks
