ArcGIS Pro - Symbology Unique Values
9914
8
01-22-2015 01:51 PM
TonyHowze
I'm working on the Prerelease arcgis pro, and maybe this will be addressed at the final release, but I am having a hard time with the unique values symbology.  Like ArcMap the default unique symbology adds the, in my opinion, the annoying "All Other Values" class.  In Pro I can't find a way to delete this, or at least NOT to show up in the legend.  How do you delete this??  How, please for the love of everything holy, how do you delete this blasted item?  Is there a default option I can nuke it forever and ever?
Unfortunately, this is very indicative of the entire software when coming from a long history in ArcMap.  I'm constantly clicking ribbons and features to try to find where the heck tools are, what needs to be active, or what didn't come over in the software as of yet.  Can we bring some of the context menus back???
JakeSkinner
Esri Esteemed Contributor
Hi Tony,
In the Symbology pane, you should have an option that says 'More'.  Click on this and you will be presented with the ability to uncheck the 'Show all other values' option.
TonyHowze
now don't I feel like an idiot <facepalm>.  I looked right past that option.
AdrianWelsh
MVP Honored Contributor
Jake,
Thanks for pointing this out. This was not very obvious to me and frustrated me for awhile!
GrahamW
Occasional Contributor II
Confusing but thank you! I have now come back to this thread on an occasional basis whenever I do something with pro.
There is effectively 3 menus here offering "more" each with their own uses. Not to mention right click options and the hidden ribbon options depending on what I click on..
deleted-user-sYHsW3p_gN5o
Agreed. I'm not sure exactly how, but it feel like the UI here could be simplified somewhat.
MichaelVolz
If you are using Unique Value for your Symbology in Pro, how can you remove just 1 or 2 values?  I see how to Remove all values, but I do not see a way to remove individual values.
TonyHowze
If you right click on the item you get an option to remove.  Make sure to click on the value or label box.
AdrianWelsh
Like what Tony said, right click on the item, and click on remove. Here is a screenshot
