How do I clip a raster with a polygon in ArcGIS 10?
245242
41
09-03-2010 01:42 PM
JennSmithyman
I have always used Hawth's tools (I have 3D Analyst not Spatial Analyst), but with the upgrade the tools disappeared....  Can I still get Hawth's tools to work with 10 or is there a function to clip by polygon that I missed?
I have approx. 100 images that I need to clip to field boundaries (polygon layer).
Thank you.
Tags (1)
DonovanCameron
Occasional Contributor II
You can use a toolbox.
Its in Data Management Tools -> Raster -> Raster Processing -> Clip
In here, you can tell it to clip to an irregularly shaped polygon.
After you specify the shapefile to clip to as your Output Extent, then you also need to ensure that you put a checkmark beside the 'Use Input Features for Clipping Geometry' option.
Is that what you needed?
DonovanCameron
myname
New Contributor III
ArcGIS support tool to clip raster/DEM or image
here for you Clip raster by polygon in ArcGIS - YouTube
JennSmithyman
Perfect.  Thank you.
For some reason, I thought that would give me extents and not the polygon boundary.
TomasNovacek
Hi, you can use Spatial Analyst Tool Extract by Mask or Extract by Polygon.
Tomas
MatejTacer
New Contributor III
Hi everybody,
The tool Extract By Mask seems to work, however, is there a way to get jpg as the output?
Thank you for your thoughts,
DonovanCameron
Hi everybody,
You can specify the output type by changing the extension in the output dataset box to Raster.jpg instead of Raster.tif, Raster.img or whatever it currently is.
Phuksouliyapommated
JeffreySwain
Don has the correct workflow.  Use the clip under Data Management > Raster > Raster Processing. If you do not specify the input geometry, you will receive the bounding extents of the polygon.  The output format of the raster is controlled by adding extensions. So .jpg for jpeg, .tif for tiff and so forth.  The only limit is the raster to be output must have the band combination/bit depth for the desired format.
Extract by Mask will also perform the clip, but Spatial Analyst is required.
andreafrustaci
Is there a way to clip a raster with a polygon but keep the outer portion? (ie, to create a donut?)
