What is the best way to load existing feature classes in to the local government template?
I've created the template on my computer in my coordinate system.
I just need to load my existing water mains created in another schema into the wMains in the government model template.
I can't find any help on this. Tech support is lacking on this as well.
Chris
Solved! Go to Solution.
Have you looked into using the Object Loader?
About loading data in ArcMap
http://resources.arcgis.com/en/help/main/10.2/index.html#//003n0000003v000000
About loading data into existing feature classes and tables
Also see the following:
Get started overview - Local Government Information Model | ArcGIS for Local Government
40895 - How are Esri application templates used in various user communities?
Mega thanks!.
