Problem with query widget in browser view
3093
02-04-2015 10:43 AM
SamJenkins
I have a problem with the query widget when used in the browser view. The query has a start date and an end date parameter to define a date range, but when viewed in the browser view I only get the start date parameter. Any ideas?
Cheers
Sam
by Anonymous User
Not applicable
Was there ever a solution for this problem?
CalenDaugherty
New Contributor III
I ran into this same issue. I found a semi work-around . . . . If you split the start date / end date query with another type of query, they seem to both show up. If the start date / end date queries are consecutive, only start date seems to appear. This worked for me, but I was unable to do a query that was only start date / end date
