Arcgis for Server download from service workaround
6479
12
02-09-2015 01:39 AM
PeriklisPanagiotidis
     As Arcgis for server has not a built in download shapefile(or any other format) functionality the "clip and ship" geoprocessing example is being suggested by many users and developers. However I find it quite limiting. As far as I understand, the "Extract Data" tool requires first to be run with a pre-defined set of Layers as a "Parameter" just like the "Zion" example.
     What I (and many other developers) need is a script/service that takes an Arcgis Server service as an input (or a relevant js object like featureset) and returns a shapefile (or any other format) as an output. Of course I am referring to a client web application. I am using the Javascript API but if I am not mistaken Flex developers face the same issue. Thanks.
AdamMouton
I too am looking for a way to export a layer.  The clip and ship is not a solution when it comes to a user picking a layer from the list to export.  Unless someone knows of a way to modify the geoprocessing service to take an the proper variables.
RobertKirkwood
Occasional Contributor III
i tried this example but it does not work:
ArcGIS API for JavaScript Sandbox
how do i create the geoprocessing service?
RobertScheitlin__GISP
Robert,
   As you probably notice, sample server 4 does not have the GP service available anymore. Here is the help doc link for creating your own clip and ship GP service:
ArcGIS Server Help - Clip and Ship
RobertKirkwood
Thanks. The link you sent only takes me to:
ArcGIS Server Help
I dint see the example. I will search for it.
Robert,
   Sorry I thought they fixed that link issue. Here is the link as plain text (don't click the link, just copy the text and paste it into your browsers address bar):
"http://help.arcgis.com/en/arcgisserver/10.0/help/arcgis_server_dotnet_help/index.html#//00930000003t..."
Hi all,
As I wrote in original post, the limitation of the above solutions is that you have to predefine the layers to clip/download. What I did to work around this limitation was to write a small script on the server, I used C# but anything will work, that provides a single service. That service takes a WFS link as an input and builds a shapefile using the GDAL library. Then wraps it up in a zip file, puts it on the server and returns a link to the file...
Not the most efficient way to do it and might time-out for large datasets but I haven't found anything better.
To avoid the timeouts you can instead of returning a link to the file, send an email with the link to the user when the zip file is ready.
I have tested libraries in js that build the shapefile on the client but they were slower and time-out a lot more.
It would be great (and surely easy to develop) if this could be done with a build in GP service.
Cheers
RobertKirkwood
i found this link in the forums:
Could Not Add The Specified Data Object to the Map
and made this work:
<!DOCTYPE html>
<html>
  <head>
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <title>Extract Data</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
    <style>
      html, body {
        height: 100%;
        width: 100%;
        margin: 0;
        padding: 0;
        visibility: hidden;
        font-family: sans-serif;
      .claro .dijitBorderContainer-child {
        border: none;
      .claro .dijitBorderContainer-dijitContentPane, .claro .dijitContentPane {
        padding: 0;
      .claro .dijitTitlePaneContentInner {
        line-height: 1.4em;
      #controls {
         position:absolute;
         top:1em;right:1em;
         width:auto !important;
         height:auto !important;
         z-index:10;
      #loading {
        display: none;
        vertical-align: middle;
      .freehandIcon { background-image:url(./images/i_draw_freepoly.png); width:20px; height:20px; }
      .polyIcon { background-image:url(./images/i_draw_poly.png); width:20px; height:20px;}
    </style>
    <script src="http://js.arcgis.com/3.14/"></script>
    <script>
      var gp, map;
      var selectionToolbar;
      require([
        "esri/map", "esri/config",
        "esri/layers/ArcGISDynamicMapServiceLayer",
        "esri/tasks/Geoprocessor", "esri/tasks/FeatureSet", "esri/toolbars/draw",
        "esri/symbols/SimpleFillSymbol", "esri/symbols/SimpleLineSymbol",
        "esri/graphic",
        "esri/Color",
        "dojo/dom", "dojo/dom-style", "dojo/query", "dojo/parser",
        "dijit/registry",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane",
        "dijit/TitlePane", "dijit/form/CheckBox", "dijit/form/ComboBox",
        "dojo/domReady!"
      ], function(
        Map, esriConfig,
        ArcGISDynamicMapServiceLayer,
        Geoprocessor, FeatureSet, Draw,
        SimpleFillSymbol, SimpleLineSymbol,
        Graphic,
        Color,
        dom, domStyle, query, parser,
        registry
        // Create all dijits.
        parser.parse();
        // Prevent flash of unstyled content(FOUC).
        domStyle.set(query("body")[0], "visibility", "visible");
        // Specify where the location of the proxy to use to communicate with the extract GP service.
        esriConfig.defaults.io.proxyUrl = "/proxy/";
        // Keep a reference to the loading icon DOM node.
        var loading = dom.byId("loading");
        map = new Map("map", {
          basemap: "streets",
          center: [-104.946372, 43.433484],
                    zoom: 7,
        map.on("load", initSelectionToolbar);
        var homelandSecurity = new ArcGISDynamicMapServiceLayer("https://wygiscservices-dev.wygisc.org/arcgis/rest/services/EORI/Geologic_Clip/MapServer");
        map.addLayer(homelandSecurity);
        gp = new Geoprocessor("https://wygiscservices-dev.wygisc.org/arcgis/rest/services/EORI/MyGPService/GPServer/Extract%20Data%...");
        gp.setOutSpatialReference({wkid:3857});
        registry.byId("polygon").on("click", function() {
          activateTool(this.id);
        registry.byId("freehandpolygon").on("click", function() {
        registry.byId("extract").on("click", extractData);
        function initSelectionToolbar() {
          map.graphics.clear();
          selectionToolbar = new Draw(map);
          selectionToolbar.on("draw-end", function(e) {
            selectionToolbar.deactivate();
            var symbol = new SimpleFillSymbol(
              "solid",
              new SimpleLineSymbol("dash", new Color([255,0,0]), 2),
              new Color([255,255,0,0.25])
            var graphic = new Graphic(e.geometry, symbol);
            map.graphics.add(graphic);
        function activateTool(tool) {
          // The draw.activate expects a string like "polygon" or "freehand_polygon".
          selectionToolbar.activate(tool);
        function extractData(){
          //get clip layers
          var clipLayers = [];
          if ( registry.byId("layer3").get("checked") ) { clipLayers.push("Bedrock Geology"); }
          if ( clipLayers.length === 0 || map.graphics.graphics.length === 0 ) {
            alert("Select layers to extract and draw an area of interest.");
            return;
          var featureSet = new FeatureSet();
          var features = [];
          features.push(map.graphics.graphics[0]);
          featureSet.features = features;
          var params = {
            "Layers_to_Clip": clipLayers,
            "Area_of_Interest": featureSet,
            "Feature_Format": registry.byId("formatBox").get("value")
          domStyle.set(loading, "display", "inline-block");
          gp.submitJob(params, completeCallback , statusCallback, function(error){
            alert(error);
            domStyle.set(loading, "display", "none");
        function completeCallback(jobInfo){
          if ( jobInfo.jobStatus !== "esriJobFailed" ) {
            gp.getResultData(jobInfo.jobId, "Output_Zip_File", downloadFile);
        function statusCallback(jobInfo) {
          var status = jobInfo.jobStatus;
          if ( status === "esriJobFailed" ) {
            alert(status);
            domStyle.set("loading", "display", "none");
          else if (status === "esriJobSucceeded"){
        function downloadFile(outputFile){
          var theurl = outputFile.value.url;
          window.location = theurl;
    </script>
  </head>
  <body class="claro">
    <div data-dojo-type="dijit/layout/BorderContainer"
         data-dojo-prps="gutters:false"
         style="width: 100%; height: 100%;margin:0;">
      <div id="map"
           data-dojo-type="dijit/layout/ContentPane"
           data-dojo-props="region:'center'">
        <div data-dojo-type="dijit/TitlePane"  data-dojo-props="title:'Extract Data'" id="controls">
          1.Select area of interest
          <br>
          <button id="polygon"
            data-dojo-type="dijit/form/Button"
            data-dojo-props="iconClass:'polyIcon', showLabel:false">
              Polygon
          </button>
          <button id="freehandpolygon"
            data-dojo-type="dijit.form.Button"
            data-dojo-props="iconClass:'freehandIcon', showLabel:false">
              Freehand
          </button>
          <br><br>
          2.Select Layers to extract data from
          <br>
          <input id="layer3" data-dojo-type="dijit/form/CheckBox" checked="checked" type="checkbox"/>
          <label for="layer3">Incident Area</label>
          <br><br>
          3.Specify download format
          <br>
          <select data-dojo-type="dijit/form/ComboBox" id="formatBox">
            <option>Shapefile - SHP - .shp</option>
            <option>File Geodatabase - GDB - .gdb</option>
            <option>Autodesk AutoCAD - DXF_R2007 - .dxf</option>
            <option>Autodesk AutoCAD - DWG_R2007 - .dwg</option>
            <option>Bentley Microstation Design (V8) - DGN_V8 - .dgn</option>
          </select>
          <br><br>
          <button id="extract" data-dojo-type="dijit/form/Button">Extract Data</button>
          <img id="loading" src="images/loading.gif">
        </div>
      </div>
     </div>
  </body>
</html>
RobertKirkwood
One problem i am having with the tutorial is that it wont let me do this:
  1. Expand Toolboxes > System Toolboxes > Server Tools.tbx > Data Extraction > Extract Data Task.
  2. Drag the Extract Data Task tool to the ArcMap table of contents.
I get the error object could not be added to the map.
KevinHibma
You must be using the 10.0 version of the tutorial. Try the 10.1+ version here:   Geoprocessing service example: Clip And Ship—Sharing geoprocessing workflows | ArcGIS for Desktop
(The steps you mention are telling you to make a "tool layer", a concept that does not exist in 10.1+)
