What file is customized pop-up information stored (WAB-Dev)
4285
02-09-2015 07:24 PM
RebeccaStrauch__GISP
This question is specifically for the LocalLayerWidget and AccessifizrWidget  but may also be generic WAB-Dev.
Where do the pop-up customization items get written?  I'm used the LocalLayer.  in a previous version of the widget (1.3 maybe) and I did quite a bit of customization using that widget version.  I made enough tweaks from the defaul WAB install, that I decided to start fresh and move things over, as appropriate.  But I have not been able to find which folder/file these tweaks are written to within my App# folders.
Can someone point me to the file....or is it multiple locations?  I was hoping to save some time by modifying the code (vs. drilling down in all the windows again).
thanks.
RobertScheitlin__GISP
Rebecca,
   You can find the changes in the server\apps\XX\configs\LocalLayer\config_Local Layer Widget.json file
Rebecca,
Excellent.  Thank you, it would have taken me a while to find (figure out) that they were in the "configs" folder....although, now it seems obvious.  funny thing,... for some reason a file-text search or the \XX\ app folder never came up with that directory.....not sure why. hmm.
