How do you set a custom javascript widget's size?
9612
02-10-2015 05:12 PM
LanceGoens
New Contributor III
I'm brand new to working with dojo and the WAB. I'm creating a custom widget and I'm trying to control the default size of the container "window" that opens to house the widget. It seems that if I add the widget to the header widget container/controller, the default size is 360 pixels wide and 100% tall. I've removed it from there and added it to the "1" widget button in the WAB and now I can at least adjust the size of the widget's container window once it's open, but more importantly... How/where do I set the size of the widget's container when it opens?
Web AppBuilder Custom Widgets
LanceGoens
New Contributor III
You guys may have pin pointed the correct way to do it but I found an alternative and since I'm working on a prototype / proof of concept project, quick and dirty is what I'm after.
In the app's config.json file, I added the widget and placed a position node/element with it in the json. I'm guessing I may have actually stumbled onto the correct way to do this but I'm not sure. i haven't retested the widget in the header controller with this setup but I think those widgets are locked into the default panel size. Placing this widget in the "1" spot (near the home button) is sufficient for my need and actually preferable because I need to be able to move the window to interact with the map under it. Anyway, here is the code I added to config.json in the app root where the "width" and "height" control the panel the widget panel's size:
        "position": {
          "left": 55,
          "top": 45,
          "width": 650,
          "height": 500
        "placeholderIndex": 1,
        "id": "_5",
        "positionRelativeTo": "map",
        "name": "SplicingSchedule",
        "label": "Splicing Schedule",
        "version": "1.1",
        "uri": "widgets/SplicingSchedule/Widget",
        "config": "widgets/SplicingSchedule/config.json"
steveway
In this case it sounds like you need to create a custom Panel.
Navigate to the Panel location (you should find this in your app's config.json) and make a copy of Panel.  Set the panel properties in your custom panel, then configure your widget to use the custom panel.
Hope this helps.
FC_Basson
MVP Regular Contributor
As steve way says, you can use a custom panel CSS size class.  In "js/main.js" when the tool is created with toolbar.createTool(tool, panelClass), replace panelClass with your own custom class, which you also define in "css/styles.css".
So in main.js => var mytool = toolbar.createTool(tool, "myPanel")
and in styles.css => .myPanel{height:200px /*custom height*/}
LanceGoens
New Contributor III
        "position": {
          "left": 55,
          "top": 45,
          "width": 650,
          "height": 500
        "id": "_5",
        "version": "1.1",
