How do I sum the values in a field in ArcGIS Pro?
59241
24
02-13-2015 09:57 AM
RoyceSimpson
Occasional Contributor III
I want to select a field in a table within ArcGIS Pro and get a quick look at the summation of all the values for all the selected records for that field.  For example, I have a field called "acres".  I want to select various features in the map, open the attribute table, show only the selected records, go to the "acres" field and see a summed up value for the acreage for those selected records.
Thanks for any help.
rgmingo
All you need to do is open the chart properties pane
RoyceSimpson
In Arcmap, you could right click the field header, go to "statistics" and see the "sum".  That functionality seems to be absent from Pro, but I'm hoping not.
I've been able to use the "summarize" gp tool but that creates a table every time I want to do this, which gets very cumbersome after a while.
TonyHowze
Hello Royce,
Have you figured how to sum a field in pro?  I need to know because I can't stand creating unnecessary tables to do simple sums.
DanLee
by Esri Regular Contributor
Hi, here is a place where you can vote for the functionality:
https://community.esri.com/ideas/11923
SarahLarsen
Voted.
AndrewWallick3
It's crazy this functionality doesn't exist yet. I hope they add it soon.
RoyceSimpson
Voted.
ThomasColson
MVP Frequent Contributor
This was implemented in 2.1 (https://community.esri.com/ideas/11923 )
Map2021
New Contributor III
Are you sure about that?
DanPatterson_Retired
And if you have multiple fields to do...
Statistics... Descriptive Statistics for multiple fields
