I'm using the address management template and workflows for a Statewide street centerline data set. When adding a streetname to the Master Address Guide the streetname needs to be unique using a zipcode. I've added the zipcode to the Local Government Master Street Guide.
What attribute assistant expression do I use to choose the new street name so that it matches the zipcode polygon in the Map document or the editor has added the correct zipcode in the centerline attribute.
Charline Avey
Hey Charline,
I would use the INTERSECTING_FEATURE method. ArcGIS for Local Government 10.1
So whenever you add a street feature it will populate a field of your choosing with the zipcode it intersects with.
Tim
