Address Locator Returning Lat/Long Values as Candidates
13977
02-18-2015 11:43 AM
SeanMurphy1
I have an address locator that is suppose to return place name locations. The place names the locator is based on has numbers in the name, for example, "7102-2" is a place name. Instead of returning the place name location as the match result, longitude and latitude values are returned. Using the same example, "Found: Longitude: 7102.000000; Latitude: -2.000000".
Is there a setting that can ignore the "coordinate" match type? Or another setting to fix this problem?
Thanks!
ShanaBritt
Sean:
I would suggest going through the steps outlined in the following technical article to disable coordinate search when using the address locator. 44182 - Disable finding latitude and longitude coordinates when using an address locator
-Shana
ShanaBritt
Sean:
-Shana
