vb.net - get layer properties
4199
02-23-2015 07:49 AM
AlbertoLaurenti
New Contributor III
I wrote this code to loop in my TOC:
        Dim iLyrIndex As Long
        Dim layer As ILayer
        Dim geoDataset As IGeoDataset
        ' Add raster layers into Combobox
        Dim iLayerCount As Integer
        iLayerCount = map.LayerCount
        If iLayerCount > 0 Then
            For iLyrIndex = 0 To iLayerCount - 1
                layer = map.Layer(iLyrIndex)
                If (TypeOf layer Is IRasterLayer) Or (TypeOf layer Is IMosaicDataset) Or (TypeOf layer Is IRasterCatalogLayer) Or (TypeOf layer Is IGdbRasterCatalogLayer) Then
                    cboBox.Items.Add(layer.Name)                ' <---- mosaic dataset DO NOT shows here!
                Else
                    MsgBox(layer.Name)          ' <---- mosaic dataset shows here!
                End If
            Next iLyrIndex
        End If
The code works well with raster layer and raster catalogs, but not with raster mosaic dataset.
If I double-click on the mosaic dataset in the TOC (grouping the Boundary, Footprint and Image layers) and then the "Source" tab in the Layer Properties Dialog the Data Type is Mosaic Dataset.
So, what's wrong? Please, any help?
Thanks a lot in advance
JeffMatson
Occasional Contributor III
It should work if you check for IMosaicLayer instead of IMosaicDataset.
JeffMatson
AlbertoLaurenti
New Contributor III
Thanks Jeff! That's correct!
I've tried with IMosaicDataset and IMosaicRaster.... missing IMosaicLayer!
