ArcGIS silverlight API windowspanel and Collapsiblepanel in another program
3790
02-24-2015 02:39 PM
LuChen
I am deploying my ArcGIS silverlight api application into another project
and the UserControls (WindowPanel and CollapsiblePanel) don't work at all in another project file. and I changed the resource directory under my current project  in generic.xaml .But they still don't work. Please help me out
Thank you!
DominiqueBroux
Esri Frequent Contributor
To get them working you have to:
- copy the usercontrols xaml and c# codes to your project
- change the namespaces to your project namespace
- create a generic.xaml file under themes that includes your usercontrol xaml. Something like:
<ResourceDictionary
    xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
    xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml">
    <ResourceDictionary.MergedDictionaries>
        <ResourceDictionary Source="/yourapp;component/UserControls/WindowPanel.xaml" />
        <ResourceDictionary Source="/yourapp;component/UserControls/CollapsiblePanel.xaml" />
    </ResourceDictionary.MergedDictionaries>
</ResourceDictionary>
LuChen
Thank you very much for you respond. I tried and it still didn't work for me.
But I got it work finally by your steps plus one more step. I add the x:name
DominiqueBroux
I am curious: x:name of what?
LuChen
hello,
I reviewed my code. here is my solution to figure out the problem. I didn't use generic.xaml. but I put all the merge directory in the app.xaml. and I add the x:Key in the window panel style . here is my codes look like:
<Style x:Key="Windowpanel">
<Setter Property="Effect" Value="{StaticResource dropShadow}" />
<Setter Property="HorizontalContentAlignment" Value="Stretch" />
<Setter Property="VerticalContentAlignment" Value="Stretch" />
<Setter Property="Background" Value="{StaticResource CommonBackgroundBrush}" />
</Style>
<ResourceDictionary Source="/dms_geo;component/Map/Arc/Styles/NavigationStyle.xaml" />
<ResourceDictionary Source="/dms_geo;component/Map/Arc/UserControls/WindowPanel.xaml" />
<ResourceDictionary Source="/dms_geo;component/Map/Arc/UserControls/CollapsiblePanel.xaml" />
</Application.Resources>
Application>
