Various reference scales within annotation
3848
02-25-2015 10:30 AM
RemiBrisson
Hello, is there a way to have annotations at various reference scales wthin the same class or group? I'm building a map book with DDP where each map is a different scale and I want the annotations (created from labels) to show with the same size on all maps. Does this makes sense? Right now, the labels show OK but when I create annotations from them, only one map has the annotations show properly...
Remi
Occasional Contributor III
Yes, there is, depending on which type of annotation you're using.  The Tiled Labels to Annotation tool, used alongside a reference scale field, will do this for you.
For this type of question, also consider using Esri's Ask A Cartographer site; it has proven more helpful for my cartographic questions than the regular forums: Esri Mapping Centre - Ask a Cartographer
RemiBrisson
Hi Marianne, thanks for the hint. I'll look into this. Much appreciated!
