My staff have been troubled with Deed Drafter failing to provide the area of cogo'd descriptions. It isn't a matter of closure since DD is reporting High Accuracy, but simply the field that normally contains the area calculated returns "Invalid" instead. Has anybody else experienced this and found a solution? Thanks.
Solved! Go to Solution.
Note: I'm not on the team that handles that application.
A search led to the github repository and a bug/enhancement:
When entering a parcel counterclockwise, the calculated area is not presented
Could that be what's happening?
Thank you Melita. I had searched github without success, which is nothing out of the ordinary for me, so you've not only answered my question but you've motivated me to not give up utilizing github. Thanks again.
