How to retrieve image from layerLegendinfos in esri flex api?
3765
02-26-2015 03:00 PM
YinglunLiang
Hi, everyone.
I'm, currently building a flexviewer print widget with customized layout, and with a custom Legend. Basicly just need pairs of sublayer names and the symbol image in the custom Legend.
So far I managed to set getLegendResult() successfully and have a respond for my layerLegendInfos, and I've got the sublayer's name. But I've spent some hard time trying to retrieve the image from layerLegendinfos and set it as image source in the custom Legend.
Anyone knows the trick here? Possible code would be awesome.
And I've got the response contents from layerLegendInfo:
(com.esri.ags.layers.supportClasses::LayerLegendInfo)#0
  layerId = "0"
  layerLegendInfos = (null)
  layerName = "PROPERTY_DIMS_text_1"
  layerType = "Feature Layer"
  legendItemInfos = (Array)#1
  maxScale = 0
  minScale = 1250
  showInLegend = true
  visible = true(com.esri.ags.layers.supportClasses::LayerLegendInfo)#0
  layerId = "1"
  layerName = "CityLimits"
    [0] (com.esri.ags.layers.supportClasses::LegendItemInfo)#2
      imageURL = (null)
      label = ""
      symbol = (com.esri.ags.symbols::PictureMarkerSymbol)#3
        angle = 0
        height = 0
        source = (flash.utils::ByteArray)#4
          bytesAvailable = 146
          endian = "bigEndian"
          length = 146
          objectEncoding = 3
          position = 0
        width = 0
        xoffset = 0
        yoffset = 0
      values = (null)
  maxScale = 0
  minScale = 0
  showInLegend = true
  layerId = "2"
  layerName = "Parcelpolygon"
      imageURL = (null)
      label = ""
        angle = 0
        height = 0
          bytesAvailable = 150
          length = 150
          objectEncoding = 3
          position = 0
        width = 0
        xoffset = 0
        yoffset = 0
      values = (null)
  maxScale = 0
  minScale = 0
  showInLegend = true
  visible = true
Seems the Image source is in ByteArray format, and I'm not sure how to deal with this ByteArray source and get the actual image.Plus can't see any color or size infomation here. Also, I didn't see a property which can give me access to the image source, just the "source = (flash.utils::ByteArray)#4" in the response. Pretty much stuck here.
First time here, sorry about the codeformat.
