Relationship data in WebApp Builder
8485
8
03-02-2015 07:33 AM
IonutAlixandroae
I have a question regarding showing related data in ArcGIS Online, more specific in an app created with Web App Builder.
I can see related data in a web map ( click: show related...) but I can not see it in the app. I understood that I should configure pop-ups to show the related data but I need more specific information about that.
Could someone explain or give some details about this subject please?
Ionut
JakeSkinner
Esri Esteemed Contributor
Hi Ionut,
There is a scheduled update tonight for ArcGIS Online.  This update includes Web AppBuilder support for related records in pop-ups, attribute table, and query results.
IonutAlixandroae
Hi Jake,
Well, I`m happy to hear that
I`ll wait until tomorrow and looking forward to test those updates.
Thank you very much !!
Ionut
TobiasFimpel1
Occasional Contributor III
Jake, how do you find out about scheduled updates? Is there a webpage somewhere that lists concrete dates? Thanks.
IonutAlixandroae
Hello Jake,
I opened again my app and saw these updates ( now I can see my related records both in web map and web mapping application/web app builder). The thing is that I want to use these related records to make some queries ( using query widget in web app builder) and for that I have configured the pop-up to include also the related records but the problem is that the data is returned modified....all my related records appears in the pop-up as "1" or "0" and some "data records" as 1970 year by default... So I can see my related tables( the fields) but the data is modified or missing...
P.S. - If I check the data clicking "Show related records" to appear the table at the bottom, the fields and data are correct, but if I want to check it in the pop-up, there is where the problem occurs.
P.S.S. - I checked the documentation and saw that on 1:M relationships, the string fields are counted( so practically where is 1 that means that is 1 record). Could I do something that the pop-up shows the records not the count for string/date/numeric fields?
Thank you,
Ionut
NataliyaLys
I am having the same issue with "show related record", when I click it in the pop-up the table at the bottom opens? but now related records are shown in the pop-up?
AnnKitowski
New Contributor III
I am having this same issue.  All I see is the count in the popup.  If I have 8 related records, are each of these records viewable at all in the popup?  Or do I just have to open the table?
RayMangan2
New Contributor III
Having what I think is a similar issue here so I'll post here. When publishing via web app builder (Launchpad theme) the popup window will display the link at the bottom "show related records", but upon publishing the app and viewing the "show related records" link is missing.
Any ideas?
SimonTait
Why does show / edit related records work well in Collector but not in Web Maps / Web App Builder or are we missing something?
