How to dissolve features and retain fields/values
5690
11
03-02-2015 08:54 AM
GeoffreyWest
Occasional Contributor III
I have a feature class with 3 point features, I would like to dissolve these so that my 3 features maintain all fields and values in one feature.
I would like one feature that has SRAddress, SRNumber, Type, E-WasteType1, Count1, E-WasteType2, Count2, E-WasteType3, Count3
Tags (1)
DarrenWiens2
MVP Honored Contributor
There's probably a much simpler way to get at this (i.e. a time-saving tool or more efficient use of dictionary, etc.), but here's how you can dump the list of values into a new field ("ItemList"), then dissolve. Note that you'll have to change the feature class name, "Electronic" field name (I was using a shapefile, so couldn't fit long name), and add a text field called "ItemList".
>>> valueList = [] # empty list
... with arcpy.da.SearchCursor("SR_Data",["SRAddress","SRNumber"]) as cursor:
...     for row in cursor:
             # get all combinations of SRAddress & SRNumber
...         valueList.append(row[0]+str(row[1]))
     # make unique value set
... valueSet = set(valueList)
     # convert set to dictionary keys
... valueDict = dict.fromkeys(valueSet)
... with arcpy.da.SearchCursor("SR_Data",["SRAddress","SRNumber","Electronic","ItemCount"]) as cursor:
             # create comma-separated list of values matching each dictionary key
...         if not valueDict[row[0]+str(row[1])]:
...             valueDict[row[0]+str(row[1])] = str(row[2]) + ', ' + str(row[3])
...         else:
...             valueDict[row[0]+str(row[1])] = str(row[2]) + ', ' + str(row[3]) + ', ' + str(valueDict[row[0]+str(row[1])])
... with arcpy.da.UpdateCursor("SR_Data",["SRAddress","SRNumber","ItemList"]) as cursor:
             # write comma-separated list for each row, matching SRAddress & SRNumber
...         row[2] = valueDict[row[0]+str(row[1])]
...         cursor.updateRow(row)
JoeBorgione
Personally, I would crack out the data into a different table and then use a relate.
Is there a specific reason you are using multipoint data?
If you really need it to be a single point with multiple fields, you're going to have to do some table manipulation on your original table, such that you have one record per site and then perform a join into your point feature class and export the joined feature class into yet another feature class.
DarrenWiens2
...         else:
GeoffreyWest
Hi Darren, This is the type of solution I was looking for, however, are you suggesting dissolving the itemlist field??  This will only maintain that field.  I would one feature with the fields SRAddress, SRNumber, Type, Electronic 1, Count 1, Electronic 2, Count 2, Electronic 3, Count 3, up until 10.
DarrenWiens2
I would dissolve based on SRAddress, SRNumber, Type, and ItemList, which includes electronic 1, count 1, etc. You can dissolve on multiple fields, even if they all match, in order to carry those fields forward.
My code above does not consider Type, but you could add it in amongst the references to SRAddress and SRNumber.
I would not suggest adding new fields for each item and count in ItemList - changing the schema like this causes all kinds of problems. It's easier to parse one defined field into components.
GeoffreyWest
Darren, A couple of questions, I would like to do the same for another field, but there is not always a guaranteed 1-1 relationship between items and comments.  Is there a way to implement a loop for the rows instead of using the index? For instance, when I try to insert a comments field and concatenate all comments for the associated request, my output becomes truncated giving me only 1 itemcount and itemtype.
"ListOfLa311ServiceRequestNotes": {
                        "La311ServiceRequestNotes": [
                                "Comment": "Out on the sidewalk near the curb.  Hopefully it is still there.",
                                "CommentType": "Address Comments",
                                "CreatedByUser": "MYLATHREEONEONE",
                                "CreatedDate": "02/17/2015 16:53:26",
                                "Date1": "",
                                "Date2": "",
                                "Date3": "",
                                "FeedbackSRType": "",
                                "IntegrationId": "021720151654176661",
                                "IsSrNoAvailable": "",
                                "ListOfLa311SrNotesAuditTrail": {},
                                "Notification": "N",
                                "Text1": ""
                                "Comment": "So glad to get rid of this old junk.  Thanks.",
                                "CommentType": "External",
                                "Date1": "",
                                "Date2": "",
                                "Date3": "",
                                "IntegrationId": "021720151654176662",
                                "Text1": ""
import json
import jsonpickle
import requests
import arcpy
fc = "C:\MYLATesting.gdb\MYLA311"
if arcpy.Exists(fc):
  arcpy.Delete_management(fc)
ListTable ="C:\MYLATesting.gdb\MYLA311Dissolve"
if arcpy.Exists(ListTable):
  arcpy.Delete_management(ListTable)
f2 = open('C:\Users\Administrator\Desktop\DetailView.json', 'r')
data2 = jsonpickle.encode( jsonpickle.decode(f2.read()) )
url2 = "myURL"
headers2 = {'Content-type': 'text/plain', 'Accept': '/'}
r2 = requests.post(url2, data=data2, headers=headers2)
decoded2 = json.loads(r2.text)
items = []
for sr in decoded2['Response']['ListOfServiceRequest']['ServiceRequest']:
    SRAddress = sr['SRAddress']
    latitude = sr['Latitude']
    longitude = sr['Longitude']
    SRNumber = sr['SRNumber']
    FirstName = sr['FirstName']
    LastName = sr['LastName']
    HomePhone = sr['HomePhone']
for ew in sr["ListOfLa311ElectronicWaste"][u"La311ElectronicWaste"]:
        CommodityType = ew['Type']
        ItemType = ew['ElectronicWestType']
        ItemCount = ew['ItemCount']
for comm in sr["ListOfLa311ServiceRequestNotes"][u"La311ServiceRequestNotes"]:
        Comment = comm['Comment']
        items.append((SRAddress,
                      latitude,
                      longitude,
                      CommodityType,
                      ItemType,
                      SRNumber,
                      ItemCount,
                      FirstName,
                      LastName,
                      Comment,
                      HomePhone))
import numpy as np    #NOTE THIS
dt = np.dtype([('SRAddress', 'U40'),
                ('latitude', '<f8'),
                ('longitude', '<f8'),
                ('Type', 'U40'),
                ('ElectronicWestType', 'U40'),
                 ('SRNumber', 'U40'),
                ('ItemCount', 'U40'),
                ('FirstName', 'U40'),
               ('LastName', 'U40'),
                ('Comment', 'U40'),
               ('HomePhone', 'U40')])
arr = np.array(items,dtype=dt)
sr = arcpy.SpatialReference(4326)
arcpy.da.NumPyArrayToFeatureClass(arr, fc, ['longitude', 'latitude'], sr )
arcpy.AddField_management(fc, "SRList", "TEXT", 255)
arcpy.AddField_management(fc, "Comments", "TEXT", 255)
with arcpy.da.SearchCursor(fc,["SRAddress","SRNumber"]) as cursor:
    for row in cursor:
with arcpy.da.SearchCursor(fc,["SRAddress","SRNumber","ElectronicWestType","ItemCount", "Comment"]) as cursor:
     for row in cursor:
         else:
with arcpy.da.UpdateCursor(fc,["SRAddress","SRNumber","SRList"]) as cursor:
     for row in cursor:
arcpy.Dissolve_management(fc, "C:\MYLATesting.gdb\MYLA311Dissolve", ["SRNumber", "SRAddress", "Type", "SRList", "FirstName", "LastName", "HomePhone", "Comment"])
print json.dumps(decoded2, sort_keys=True, indent=4)
GeoffreyWest
When running your code and switching the parameters, I receive an error that says
line 29, in <module>
StopIteration: iteration not started
import arcpy
    for row in cursor:
with arcpy.da.SearchCursor(fc,["SRAddress","SRNumber","ElectronicWestType","ItemCount"]) as cursor:
     for row in cursor:
         else:
with arcpy.da.UpdateCursor(fc,["SRAddress","SRNumber","ItemList"]) as cursor:
     for row in cursor:
DarrenWiens2
Make sure the line "cursor.updateRow(row)" is at the same indentation level as the previous line ("row[2] = ...").
GeoffreyWest
Darren, I marked your question correct as it does answer part of it that I really didn't specify.  Please see the end of this thread for clarification.  https://community.esri.com/message/459452?et=watches.email.thread#459452
IanMurray
you just need to indent your last line to the same indentation as the last line, otherwise its running outside of your for-loop
