Web Map "set visibility range" not saving
5509
03-04-2015 08:00 AM
deleted-user-Np_HetqJeO36
I am creating a web map with custom visibility ranges on different layers. This web map is used in differing applications and story maps.
After I have the visibility ranges set for all the layers the way I want them to show/hide within an app/storymap, I save the map and return to "my content". When I reopen the map in a viewer, the visibility ranges I previously set have all been changed. Is there a way to get the visibility settings to stay with the map after I save it?
GregoryL_Azou
Occasional Contributor III
Looks like it is a know issue Bug? Set Visibility Range Won't Save in ArcGIS.com after Dec Update
I suggest that you jump in that thread.
MarkFleming
New Contributor III
Correct that: When tiling the new image, I had it set for the highest level of detail (20, Building)
The old image is set for "Room" as the highest level of detail. I don't see this setting when I create the new tile package now. The image disappears way before I get to Building detail, much less Room.
KellyGerrow
Esri Frequent Contributor
Hi Mark,
This previous discussion may help you to create a tiled service down to the room level.
https://community.esri.com/message/646811-tiled-image-in-arcgis-online-does-not-let-me-zoom-in-far?s...
-Kelly
AdrianHughes3
I'm trying to set the visibility range of  a custom vector basemap for  a story map. When saving the web map and reopening, the visibility range returns to the original range
