Does GeoForm Only Work With ArcGIS Online
4167
03-05-2015 02:16 PM
RandyKreuziger
Occasional Contributor III
Will GeoForm work with editable feature services from any ArcGIS Server or does it only work with ArcGIS Online services?
TobiasFimpel1
I believe you can add the ArcGIS Server Feature Service to the web map, and then just use that web map for the GeoForm. At least that's how it used to work in the previous version of the GeoForm.
RickeyFight
MVP Regular Contributor
Randy,
Did you ever figure this out?
We do not want a AGOL map.
KellyGerrow
Esri Frequent Contributor
Hi Rickey,
You will need to create a web map and use an editable feature service (Hosted or Server) in order to use the application.
Cheers,
Kelly
RickeyFight
I wish there was another way but I found a solution:
I was trying to get a map that anyone can add info but not see the points since the data was not public knowledge.
What I ended up doing was add a definition query to created date  = some point the past.
That way they could add points and the points would instantly disappear because the definition query would hide them.
