Trying to publish gp service via modelbuilder gp results... locked outputs
4357
9
03-05-2015 12:17 PM
RoyceSimpson
Occasional Contributor III
I've got a model, that I can successfully run in Arcmap over and over (because I've checked the geoprocessing option to "Overwrite the outputs of geoprocessing operations".  However when I publish this to our ArcGIS Server (AGS) as a gp service, I can run it once then the outputs get locked and I can't successfully run it again. If I stop and restart the gp service in AGS I can run the gp task one time, then the outputs get locked again and I'm dead in the water.
Is there somehow a way to replicate the ArcMap "Overwrite the outputs of geoprocessing operations" setting in AGS to allow these outputs to get overwritten?
-Royce
DavidColey
Right, so that dbf has to be output as an inMemory table, it can't remain as physical dbf somewhere.  I have a model that basically does a select by attribute and then a re-select by locataion. It's set up like this:
the output point locations parameter is specified in the tools as
in_memory\OutputPoints
When I publish that result to server from the Results window it works every time becasue the output feature is an inMemory feature.  I'm sure it will work the same with a dbf.
DavidColey
Royce, are you outputting to an inMemory feature class?
RoyceSimpson
The output is a dbf file called "clipResults.dbf".  There are also two associated lock files for each of our AGS servers in that cluster:  "clipResults.dbf.ARETE.6352.9956.sr.lock" and "clipResults.dbf.COL.15756.21172.sr.lock".
If I try to run the gp service task and those locks are there, I get the following AGS error.  The only way to not get the error is to stop and restart the service, which clearly isn't anything but a very short term solution:
Error executing tool.: ERROR 000258: Output \\lcgfs02\gisserverdata\gp\output\landcover\clipResults.dbf already exists Failed to execute (Table to Table). Failed to execute (Model).
DavidColey
RoyceSimpson
I'm trying that method as we speak!  I can't output to "dbf" though and still have it as "in_memory"... so I took the "dbf" extension off and ran the model and it worked.  I'm republishing now.  Crossing fingers.
RoyceSimpson
Holy Shzam!  That worked.  "in_memory" is what fixed it!  woot!  Thanks David.
DavidColey
Thanks man, they're tricky aren't they?  Are you going to Dev Summit next week?
RoyceSimpson
No... UC for me.
DavidColey
great, have fun.  I'm heading to Dev... still haven't forgotten about that Collector setup either, just haven't got to it yet...
RoyceSimpson
Ah yes, Collector.  I've got esri looking into it right now.  So far, it's looking like an Oracle bug.  Will keep the thread updated as needed.
