Water Utilities Network Reporting Toolbar - Valve Isolation Configuration Enhancement
3720
03-10-2015 08:16 AM
MarietteShin
New Contributor III
We really like the Valve Isolation tool in the Reporting Toolbar. However, it would be nice if there was greater flexibility with the configuration file or if it were more customizable.
We have an old Pressure Zone modeling tool currently in VBA, which we would really love to have work, with some minor customization, with this reporting toolbar. To make our pressure zone modeling tool work, we need to allow users to not only select the "TraceIsolation_Operable_Field_Valves" field value, but to define the two field values as something other than "0/1" or "false/true".
For a Pressure Zone modeling tool, we need to be able to use a "Position" field in our Valves layer with values of "On" or "Off" that dictate whether the valve is enabled or not.
Similarly, we have a Pump Stations layer that we need to be able to set as operable, depending upon whether the pump station is a booster pump station or not. Our infrastructure is more complicated than in other water districts because of our complicated topography.
We would also like a way to query out and define our Regulator Valves as barriers, but it doesn't look like there's a way to do this with the current reporting toolbar code?
If there is a way to do the above, and I'm just not understanding the configuration file and code the way it's meant to be, than would some one please let me know. Thanks.
