Esri services privilege
4626
10
03-14-2015 10:59 PM
yousofothman
New Contributor III
i have these application
AlQassimExplorer
i want to add user and give them privilege to edit layer
how can i do these in silverlight
Asgharkhan
Plz kindly Check This Examples , Modifying of this examples may fix your problem.
arcgis-samples-silverlight/src/ArcGISSilverlightSDK/Security at master · Esri/arcgis-samples-silverl...
Regards
Asgharkhan
you can add sign in script before editing tool,
yousofothman
New Contributor III
thank you for replying
please more detials
Asgharkhan
Regards
yousofothman
New Contributor III
I think these will help me
i will try it thank you
Asgharkhan
can u share with me بحث عن خدمه  query codes , i want some help from your codes , i have relay no idea how bind multiple combobox with each others.
yousofothman
New Contributor III
of course
take these:
 private void ServiceQueryComboBoxy_SelectionChanged(object sender, SelectionChangedEventArgs e)
            ESRI.ArcGIS.Client.Tasks.Query Servquery = new ESRI.ArcGIS.Client.Tasks.Query();
            QueryTask ServqueryTask = new QueryTask();
            //FindTask FindTask = new FindTask();
            if (ServiceQueryComboBoxy.SelectedIndex == -1)
                return;
            else if (ServiceQueryComboBoxy.SelectedIndex == 0)
                ServqueryTask = new QueryTask("http://84.235.15.69:8399/arcgis/rest/services/Expr_Operational/MapServer/6");
                Servquery.OutFields.AddRange(new string[] { "SRV_NAME", "CITY_NAME", "ST_GENDER", "STATUS", "DISTRICT_NAME", "Shape" });
            else if (ServiceQueryComboBoxy.SelectedIndex == 1)
                ServqueryTask = new QueryTask("http://84.235.15.69:8399/arcgis/rest/services/Expr_Operational/MapServer/7");
                Servquery.OutFields.AddRange(new string[] { "SRV_NAME", "CITY_NAME", "DISTRICT_NAME", "Shape" });
            else if (ServiceQueryComboBoxy.SelectedIndex == 2)
                ServqueryTask = new QueryTask("http://84.235.15.69:8399/arcgis/rest/services/Expr_Operational/MapServer/5");
                Servquery.OutFields.AddRange(new string[] { "SRV_NAME", "DISTRICT_NAME", "STATUS", "TYPE", "Shape" });
            else if (ServiceQueryComboBoxy.SelectedIndex == 3)
                ServqueryTask = new QueryTask("http://84.235.15.69:8399/arcgis/rest/services/Expr_Operational/MapServer/4");
                Servquery.OutFields.AddRange(new string[] { "SRV_NAME", "CITY_NAME", "STATUS", "DISTRICT_NAME", "Shape" });
            else if (ServiceQueryComboBoxy.SelectedIndex == 4)
                ServqueryTask = new QueryTask("http://84.235.15.69:8399/arcgis/rest/services/Expr_Operational/MapServer/3");
                Servquery.OutFields.AddRange(new string[] { "SRV_NAME", "TYPE", "CITY_NAME", "DISTRICT_NAME", "Shape" });
            else if (ServiceQueryComboBoxy.SelectedIndex == 5)
                ServqueryTask = new QueryTask("http://84.235.15.69:8399/arcgis/rest/services/Expr_Operational/MapServer/1");
                Servquery.OutFields.AddRange(new string[] { "SRV_NAME", "CITY_NAME", "STATUS", "TYPE", "DISTRICT_NAME", "Shape" });
            //Expr_Operational Layer 1 link:
            ServqueryTask.ExecuteCompleted += ServicesQueryTask_ExecuteCompleted;
            ServqueryTask.Failed += QueryTask_Failed;
            Servquery.ReturnGeometry = true;
            if (FindServiceDetailsDataGrid.SelectedItem != null)
                Servquery.Text = FindServiceDetailsDataGrid.SelectedItem.ToString();
            Servquery.Where = "[DISTRICT_NAME] ='" + DestrictQueryForServComboBoxy.SelectedItem.ToString() + "'";
            Servquery.OutSpatialReference = MyMap.SpatialReference;
            Binding resultFeaturesBinding = new Binding("LastResult");
            resultFeaturesBinding.Source = ServqueryTask;
            FindServiceDetailsDataGrid.SetBinding(DataGrid.ItemsSourceProperty, resultFeaturesBinding);
            ServqueryTask.ExecuteAsync(Servquery);
        private void ServicesQueryTask_ExecuteCompleted(object sender, ESRI.ArcGIS.Client.Tasks.QueryEventArgs args)
            FeatureSet featureSet = args.FeatureSet;
            #region Display Graphic and Data
            // If an item has been selected
            GraphicsLayer graphicsLayer = MyMap.Layers["MyGraphicsLayer"] as GraphicsLayer;
            graphicsLayer.Graphics.Clear();
            if (featureSet.Features.Count > 0)
                // Show selected feature attributes in DataGrid
                Graphic selectedFeature = featureSet.Features[0];
                QueryDetailsDataGrid.ItemsSource = selectedFeature.Attributes;
                // Highlight selected feature
                string s = selectedFeature.Geometry.ToString();
                string left = s.Substring(0, 5);
                switch (left)
                    case "Polyg":
                        selectedFeature.Symbol = LayoutRoot.Resources["DefaultFillSymbol"] as ESRI.ArcGIS.Client.Symbols.Symbol;
                        break;
                    case "Polyl":
                        selectedFeature.Symbol = LayoutRoot.Resources["DefaultLineSymbol"] as ESRI.ArcGIS.Client.Symbols.Symbol;
                        break;
                    case "Point":
                        selectedFeature.Symbol = LayoutRoot.Resources["DefaultMarkerSymbol"] as ESRI.ArcGIS.Client.Symbols.Symbol;
                        // Zoom to selected feature (define expand percentage)
                        ESRI.ArcGIS.Client.Geometry.Envelope selectedFeatureExtentPoint = selectedFeature.Geometry.Extent;
                        ESRI.ArcGIS.Client.Geometry.Envelope displayExtentPoint = new ESRI.ArcGIS.Client.Geometry.Envelope(
                        selectedFeatureExtentPoint.XMin - (500 / .5),
                        selectedFeatureExtentPoint.YMin - (500 / .5),
                        selectedFeatureExtentPoint.XMax + (500 / .5),
                        selectedFeatureExtentPoint.YMax + (500 / .5));
                        MyMap.ZoomTo(displayExtentPoint);
                        break;
                graphicsLayer.Graphics.Add(selectedFeature);
                ESRI.ArcGIS.Client.Geometry.Envelope selectedFeatureExtent = selectedFeature.Geometry.Extent;
                double expandPercentage = 30;
                double widthExpand = selectedFeatureExtent.Width * (expandPercentage / 100);
                double heightExpand = selectedFeatureExtent.Height * (expandPercentage / 100);
                ESRI.ArcGIS.Client.Geometry.Envelope displayExtent = new ESRI.ArcGIS.Client.Geometry.Envelope(
                 selectedFeatureExtent.XMin - (widthExpand / .2),
                selectedFeatureExtent.YMin - (heightExpand / .2),
                selectedFeatureExtent.XMax + (widthExpand / .2),
                selectedFeatureExtent.YMax + (heightExpand / .2));
                MyMap.ZoomTo(displayExtent);
                // If DataGrid not visible (initial load), show it
                if (DataGridScrollViewer.Visibility == Visibility.Collapsed)
                    DataGridScrollViewer.Visibility = Visibility.Visible;
                    QueryGrid.Height = Double.NaN;
                    QueryGrid.UpdateLayout();
            else
                QueryDetailsDataGrid.ItemsSource = null;
                DataGridScrollViewer.Visibility = Visibility.Collapsed;
            #endregion
        private void FindDetails_SelectionChanged2(object sender, SelectionChangedEventArgs e)
            // Highlight the graphic feature associated with the selected row
            DataGrid dataGrid = sender as DataGrid;
            int selectedIndex = dataGrid.SelectedIndex;
            if (selectedIndex > -1)
                Graphic graphic = (Graphic)FindServiceDetailsDataGrid.SelectedItem;
                QueryDetailsDataGrid.ItemsSource = graphic.Attributes;
                string attribut = graphic.Attributes["SHAPE"].ToString();
                string SubAtribut = attribut.Substring(18, 5);
                switch (SubAtribut)
                    case "Polyg":
                        graphic.Symbol = LayoutRoot.Resources["DefaultFillSymbol"] as ESRI.ArcGIS.Client.Symbols.Symbol;
                        break;
                    case "Polyl":
                        graphic.Symbol = LayoutRoot.Resources["DefaultLineSymbol"] as ESRI.ArcGIS.Client.Symbols.Symbol;
                        break;
                    case "Point":
                        graphic.Symbol = LayoutRoot.Resources["DefaultMarkerSymbol"] as ESRI.ArcGIS.Client.Symbols.Symbol;
                        ESRI.ArcGIS.Client.Geometry.Envelope selectedFeatureExtentPoint = graphic.Geometry.Extent;
                        SearchTabPanel.Visibility = Visibility.Collapsed;
                        break;
                graphicsLayer.Graphics.Add(graphic);
                //Zoom to selected feature (define expand percentage)
                ESRI.ArcGIS.Client.Geometry.Envelope selectedFeatureExtent = graphic.Geometry.Extent;
yousofothman
New Contributor III
and these is xml code :
 <Grid Background="#FFF1F1F1" Opacity="0.9">
                            <TextBlock x:Name="ServiceSearchTitleLbl"
  Foreground="#FF762F2F" FontSize="16" Margin="143,4,114,169" HorizontalAlignment="Center" FontFamily="/AlQassimExplorer;component/Fonts/Fonts.zip#Traditional Arabic" FontWeight="Bold" Width="98">
  <Run Text="بحث عن "/>
  <Run Text="خدمة"/>
                            </TextBlock>
                            <TextBlock x:Name="DestrictNameLbl"
  Foreground="#FF762F2F" FontSize="16" Margin="10,36,262,137" HorizontalAlignment="Center" FontFamily="/AlQassimExplorer;component/Fonts/Fonts.zip#Traditional Arabic" FontWeight="Bold" Width="83" Text="اسم الحي"/>
                            <TextBlock x:Name="ServiceTypeLbl"
  Foreground="#FF762F2F" FontSize="16" Margin="10,62,267,111" HorizontalAlignment="Center" FontFamily="/AlQassimExplorer;component/Fonts/Fonts.zip#Traditional Arabic" FontWeight="Bold" Width="78" Text="نوع الحدمة"/>
                            <ComboBox x:Name="ServiceQueryComboBoxy" Width="200" Height="20" SelectionChanged="ServiceQueryComboBoxy_SelectionChanged" Margin="99,68,56,111">
                                <ComboBoxItem Content="الخدمات التعليمية"/>
                                <ComboBoxItem Content="الخدمات المالية"/>
                                <ComboBoxItem Content="الخدمات الحكومية"/>
                                <ComboBoxItem Content="الخدمات الصحية"/>
                                <ComboBoxItem Content="خدمات الفنادق"/>
                                <ComboBoxItem Content="خدمات المساجد"/>
                            </ComboBox>
                            <sdk:DataGrid Visibility="Visible" SelectionChanged="FindDetails_SelectionChanged2" x:Name="FindServiceDetailsDataGrid" ColumnWidth="250" AutoGenerateColumns="False"  HeadersVisibility="Column" Background="White"
  BorderBrush="Black" BorderThickness="1" VerticalScrollBarVisibility="Visible" HorizontalScrollBarVisibility="Disabled"
  IsReadOnly="True" HorizontalAlignment="Right" SelectionMode="Single" Width="250" Margin="0,97,51,5" Height="90">
                                <sdk:DataGrid.Columns>
                                    <sdk:DataGridTextColumn Binding="{Binding Attributes[SRV_NAME]}" Header="نتيجة البحث" />
                                </sdk:DataGrid.Columns>
                            </sdk:DataGrid>
                            <ComboBox x:Name="DestrictQueryForServComboBoxy" Width="200" Height="20" SelectionChanged="ServiceDestrictQueryComboBox_SelectionChanged" Margin="100,40,55,139"/>
                            <Rectangle Fill="#FFEDE4E4" HorizontalAlignment="Left" Height="31" Stroke="Black" VerticalAlignment="Top" Width="354" Opacity="0.25">
                                <Rectangle.Effect>
                                    <DropShadowEffect Color="#FFD6B0B0"/>
                                </Rectangle.Effect>
                            </Rectangle>
                        </Grid>
yousofothman
New Contributor III
i hope these help you
Asgharkhan
Thank You Bro.........You Are Awesome
