Export Page Layout to PDF using ESRI add-in with vb.net
4246
03-19-2015 06:46 AM
TiffanySelvidge1
Occasional Contributor III
Note: This message is cross-posted on Stack Exchange (Export Page Layout to PDF using ESRI add-in with vb.net - Geographic Information Systems Stack Excha... )
I have been trying to convert a vba script to vb.net but I have hit a roadblock and am hoping someone can help me figure out the problem. I want to export the Page Layout of my map to a PDF using an add-in button. The roadblock occurs where I define my PDFCreate class. I keep receiving the error message: "Unable to cast object of type 'CreatePDF_2.PDFCreate' to type ESRI.ArcGIS.Output.IExport". I suspect the error is in my definition and relationship of the document, active view and page layout. I have looked at examples and tried different definitions and procedures but I have been unable to figure out how to fix the problem.
I am using Visual Studio 2010 Professional and ArcMap 10.2.2
Any assistance will be appreciated. Thanks.
Tiffany
Imports ESRI.ArcGIS.Carto
Imports ESRI.ArcGIS.esriSystem
Imports ESRI.ArcGIS.Geometry
Imports ESRI.ArcGIS.Output
Imports System.Windows.Forms
Imports ESRI.ArcGIS.ArcMapUI
Public Class PDFCreate
    Inherits ESRI.ArcGIS.Desktop.AddIns.Button
    Public Sub New()
    End Sub
    Protected Overrides Sub OnClick()
        PDFCreatemodule()
    End Sub
    Protected Overrides Sub OnUpdate()
        Enabled = My.ArcMap.Application IsNot Nothing
    End Sub
    Public Sub PDFCreatemodule()
        '  TODO: Sample code showing how to access button host
        Dim pMxDoc As IMxDocument
        Dim pActiveView As IActiveView
        Dim pPageLayout As IPageLayout
        Dim pExport As ESRI.ArcGIS.Output.IExport
        Dim pExportpdf As ESRI.ArcGIS.Output.IExportPDF
        Dim pPixelEnv As IEnvelope
        Dim lDPI As Long
        Dim tExpRect As tagRECT
        Dim hDC As Long
        'pMxApp = Application
        pMxDoc = My.ArcMap.Application.Document
        pActiveView = pMxDoc.PageLayout
        pPageLayout = pMxDoc.PageLayout
        pActiveView = pPageLayout
        pExport = New PDFCreate
        pExportpdf = pExport
        pPixelEnv = New Envelope
        pExport.ExportFileName = " " & ".pdf"
        pExport.Resolution = lDPI
        pExportpdf.EmbedFonts = True
        pPixelEnv.PutCoords(0, 0, lDPI * PageExtent(pPageLayout).UpperRight.X, _
                                  lDPI * PageExtent(pPageLayout).UpperRight.Y)
        pExport.PixelBounds = pPixelEnv
        ' (device coordinates origin is upper left, ypositive is down)
        tExpRect.left = pExport.PixelBounds.LowerLeft.X
        tExpRect.bottom = pExport.PixelBounds.UpperRight.Y
        tExpRect.right = pExport.PixelBounds.UpperRight.X
        tExpRect.top = pExport.PixelBounds.LowerLeft.Y
        hDC = pExport.StartExporting
        pActiveView.Output(hDC, lDPI, tExpRect, Nothing, Nothing)
        System.Windows.Forms.Application.DoEvents()
        pExport.FinishExporting()
    End Sub
    Public Function PageExtent(pPageLayout) As IEnvelope
        Dim dWidth As Double, dHeight As Double
        pPageLayout.Page.QuerySize(dWidth, dHeight)
        Dim pEnv As IEnvelope
        pEnv = New Envelope
        pEnv.PutCoords(0.0#, 0.0#, dWidth, dHeight)
        PageExtent = pEnv
    End Function
End Class
TiffanySelvidge1
No responses here but just in case this helps someone out in the future, here is the now working code.
Public Class PDFCreation
PDFModule()
End Sub
End Sub
Public Sub PDFModule()
Dim pExport As IExport
Dim lDPI As Long
Dim hDC As Long
Dim res = 96
  pMxDoc
  pPageLayout
= pMxDoc.PageLayout
  pActiveView
= pPageLayout
  pExport
= New ESRI.ArcGIS.Output.ExportPDF
  pPixelEnv
= New Envelope
  lDPI
= 300
  pExport
.Resolution = lDPI
  tExpRect
.left = 0
  tExpRect
.top = 0
  tExpRect
.bottom = My.ArcMap.Document.ActiveView.ExportFrame.bottom * (lDPI / res)
  tExpRect
.right = My.ArcMap.Document.ActiveView.ExportFrame.right * (lDPI / res)
  pPixelEnv
.PutCoords(tExpRect.left, tExpRect.top, tExpRect.right, tExpRect.bottom)
  pExport
Dim pdfName As String = ""
Dim saveFileDialog1 As New SaveFileDialog
  saveFileDialog1
.Filter = "PDF File|*.pdf"
  saveFileDialog1
.Title = "Save A PDF File"
  saveFileDialog1
.FileName = pdfName
  saveFileDialog1
.ShowDialog()
  pExport
.ExportFileName = saveFileDialog1.FileName
  hDC
  pActiveView
  pExport
.FinishExporting()
MessageBox.Show("Finished Exporting Map")
  pExport
.Cleanup()
End Sub
End Class
TiffanySelvidge1
PDFModule()
End Sub
End Sub
Dim lDPI As Long
Dim hDC As Long
Dim res = 96
  pMxDoc
  pPageLayout
= pMxDoc.PageLayout
  pActiveView
= pPageLayout
  pExport
  pPixelEnv
= New Envelope
  lDPI
= 300
  pExport
.Resolution = lDPI
  tExpRect
.left = 0
  tExpRect
.top = 0
  tExpRect
  tExpRect
  pPixelEnv
  pExport
  saveFileDialog1
  saveFileDialog1
  saveFileDialog1
.FileName = pdfName
  saveFileDialog1
.ShowDialog()
  pExport
  hDC
  pActiveView
  pExport
.FinishExporting()
  pExport
.Cleanup()
End Sub
End Class
