Identify sample not working?
680
5
09-22-2010 05:49 AM
JamesB
http://help.arcgis.com/EN/webapi/javascript/arcgis/demos/identify/identify_drilldown.html
If you click, nothing happens. If you look you'll see it's making AJAX calls, and the response is always:
dojo.io.script.jsonp_dojoIoScript17._jsonpCallback({"error":{"code":500,"message":"Server Error - Object reference not set to an instance of an object.","details":[]}});
KellyHutchins
Esri Frequent Contributor
The service that this sample uses has been deprecated. I'll replace the service and upload a new version of the identify sample soon.
JamesB
So the actual code on that page should work, it's just the service behind it has been stopped?
KellyHutchins
Correct - the code should work.
JamesB
Got the code working on our server fine, thanks
derekswingley1
Hi Kelly,
Can you clarify or list which services have been taken offline?
