Feature to kml
2724
5
09-22-2010 07:45 AM
FawnaNibert
I have all my data in a feature class and want to use a model to convert it into a kml, is there a way to do this?   So far see the tool for, save to layer file, and  layer to kml.  but I get errors when trying to use them straight off of my feature class.     I have 9.3.1
JakubSisak
Occasional Contributor III
Layer to KML should work fine. What is the error you are getting?
FawnaNibert
This is when in the model I try to connect the Feature class to, Save to Layer File Tool:
The feature class value __ does not meet the input requirements for any of the parameters for the save to layer file tool.
Input Layer: ERROR 000840: The value is not a Layer
This is when the model I try to connect the Feature class to , Layer To KML Tool:
All possible input parameters already have a value.
Layer: ERROR 000840: The value is not a Layer.
Layer Output Scale:    ERROR 000840:  The value is not a Boolean.
Extent to Export: Already has value.
Size of returned image (pixels):  ERROR 000840: The value is not a Long.
DPI of output image:   Error 000840: the value is not a Long.
I have tried to look up the ERROR  000840 but I have not get anywhere
JakubSisak
The input must be a layer.  See below thread for similar discussion:
http://forums.arcgis.com/threads/5736-Join-a-Feature-Class-to-a-Table-with-Python
"Layer To KML - This tool converts an in-memory or file-based feature or raster layer into a KML file containing a translation of ESRI geometries and symbology."
You can either use a layer in the TOC or a layer saved as a layer file.
FawnaNibert
I have figured out how to create a feature class to a KML,  you must convert the feature class to a feature layer, then layer to KML. but now I lost my information that was in the Feature.  Any ideals
JakubSisak
All you should have to do is to add  a feature class to ArcMap then drag the layer to the tool (or use the drop-down to select it) No conversion necessary; Geodatabase feature class added to ArcMap is a feature layer.
