Large cell size after using raster calculator
4897
7
03-26-2015 02:28 PM
DitlevReventlow
Occasional Contributor II
Hey Everyone.
I am multiplying two raster layer with each other using raster calculator in ArcGIS. One of them have a much coarser spatial resolution than the other.
I thought that the resulting raster cell size would be corresponding to the layer with the finer resolution because in my head this would make sense (the value of the bigger cell is simply multiplied to all the smaller cell yielding different small cells).
But when I perform the operation, the resulting cell size is corresponding to the raster layer with the coarser resolution.
How can this be? And is there some way to make the resulting raster having the finer resolution.
Thank you!
Regards,
Ditlev Reventlow.
JayantaPoddar
MVP Esteemed Contributor
As mentioned by Dan,
In Raster Calculator dialog box, Go to Environment Settings
Set the XY resolution, as desired.
Think Location
DanPatterson_Retired
No, it sometimes uses the first, set the cell size in the Environments tab of the tool
DitlevReventlow
Sorry, I am not sure where this is, where is tool?
​I assumed you were using arcmap 10.x... it is here ArcGIS Help (10.2, 10.2.1, and 10.2.2)  bottom of the dialog
JayantaPoddar
Think Location
DitlevReventlow
Ahh okay, didn't see that small menu. Thank you very much!
MattSchelly
I, too have the same problem, however with simple addition of rasters, not multiplication.  All 6 of my rasters have a 50-foot x 50-foot cell size and when added together they create a raster with a 264-foot cell size.  All 6 have been clipped to the same extent, but the rasters were created from polygon features and so they are not all exactly aligned with each other.  I used the Environment setting for XY Resolution and Toerance, but the result was 264-foot cells.
Why? Or better, how do I get 50-foot cells in my result?  Thanks!
you need to set the cell size to the desired value and the analysis extent to the union of the inputs otherwise you get a default calculation of 1/250 of the maximum of the extent width an height.  In short... if you don't set things explicitly, you get a default derived from what is thought best.
