Failed Locate Features Along Routes
4441
8
03-27-2015 09:31 AM
anayoung
New Contributor III
I am having a very frustrating issue with locating features along routes with a large polyline feature class. There is one particular polyline feature that fails the process every time and I can't figure out why. The line looks perfectly fine! There are no arcs and I even disabled z-values. I get two 999999 errors - one that simply says nothing and another that says can't find table (which is a known bug). I'm operating ArcMap 10.2.2
Please help.
Ana
XanderBakker
Esri Esteemed Contributor
Is the line a multipart feature?
Have a look at this thread: https://community.esri.com/message/459719#460119
anayoung
New Contributor III
No, it's not a multipart feature. I've attached the offending line within a zip in shapefile format. Can you take a look at it?
XanderBakker
That's odd, if I create a route from the shapefile (in a fgdb), create some random points along the route and locate them, it creates the event table. It also lets me create a route event layer from the table:
I guess I will need some more information to find out what is going wrong. BTW I used ArcMap 10.2.2.
You said you disabled the Z values, but the polyline is ZM (Z=0 and M=NaN for all the points). What type of features do you have that you want to locate along the route?
anayoung
New Contributor III
Hi Xander, Thanks for checking things out. We've got a polyline database of about 600,000 road features (LA DOTD) that we are trying to create a route feature class for so we have beginning and end log miles along the lines. The goal will be a Roads and Highways product. However, we can't get passed this step of creating the table. I encountered this particular line after creating tables in batches of a few thousand lines in one parish (county). After digging a bit on the internet to identify what could be the problem, we found that arcs could be an issue but as far as we can tell there are no arcs; also, that Z values could be an issue - so, that's why we disabled them. I'm very new to this process but I have a suspicion it has something to do with how we are creating the route feature class. My co-workers are at a loss too. What are your thoughts? Thank you, Xander. Your help is very much appreciated. Ana
XanderBakker
Before you invest a lot of time in creating your own street network, it might be worth evaluating products that are already available, like: StreetMap Premium Overview | ArcGIS Resource Center
anayoung
New Contributor III
Hi Xander,
Well, my co-worker figured out that if we use shapefiles for both the line features and the route feature class the table is created - no failure. Why this would be, I have no idea. Do you?
XanderBakker
To determine that, we should compare the geometries of both formats and revise how one was converted to the other.
For now I think most import is that you can continue with you network analysis.
anayoung
New Contributor III
Yes, I agree. It works...we'll see how it goes. ESRI has instructions for locating features along routes for both geodatabase files and shapefiles. Obviously, the shapefile procedure worked for us.
Thanks, Xander.
