Hi all,
is there a way to change the size of the ArcGIS Online Pop Up-Window? Because pictures are cut and then it looks not so fine (see attachement). And is it possible to activate a mouse over function for the pop up-window instead clicking the feature?
Thanks and best regards,
Marko
Solved! Go to Solution.
This functionality hasn't been added to the map viewer but is being considered for the future. Check out some of the configurable apps like the minimalist where you can dock the pop up on the side of the app. This may provide more flexibility for the workflow that you are looking to accomplish currently.
Also consider supporting this idea: https://community.esri.com/ideas/4590
-Kelly
Unfortunately, at this time there is no way to change the size of the popup window.
Mike
I just wanted to ask if there is still no solution for changing the popup window?
No, you still can't change the popup window size.
Mike
Any chance this feature will be added? I know you all just released a large update for AGOL and this wasn't included. I have similar problems. Why not have the preference ask where to send pop-ups (side of screen, large portion of center screen, top of screen, bottom etc...)
Seconded.
Thirded
-Kelly
Hi, Kelly
Is this still no solution now ? When can we expect this can be solved ?
Could you provide more information regarding the "minimalist" ?
Where to get it and how to make it works ?
Thanks a lot.
Da-Wei
Hi lioudawei,
The work on pop ups is not complete yet. Check out the https://community.esri.com/groups/cats?sr=search&searchId=7885d1b1-a56d-4263-9a85-66d647da4402&searc... space for more information about apps with side pop ups, especially this question: https://community.esri.com/message/685152-display-pop-up-information-in-a-side-panel?sr=search&searc...
-Kelly
