ArcGIS Online Pop Up Windows
3984
03-31-2015 01:16 PM
KevinLaughlin
New Contributor III
I have a map I wish to display embedded into a web page. I have everything set up in AGO. Is there a way - through AGO, to have to pop up window open automatically? For instance, when the iframe loads the map on the web page the pop up window display automatically appears without having to click a feature.
Kevin
deleted-user-25j2k-XonNEg
New Contributor III
I would like to do the same thing but based on a queried address - have the pop up for the polygon (only one layer in the map) display automatically.
Charlie
KellyGerrow
Esri Frequent Contributor
Try using the find and show pop up parameters described in this documentation:
Use URL parameters to modify embedded maps—ArcGIS Online Help | ArcGIS
If this isn't what you are trying to accomplish, you can look into customization and log an idea on the ideas site. ArcGIS Ideas
