Save Layer File with Python
9454
8
04-01-2015 07:07 PM
PierreKurth
Hi there,
I am working on a Multi-scale layer map using ArcMap.
Since I have several hundred of different map layer in my *.mxd I'd like to save for each individual map layer a Layer File.
I found a script which already works but I'd like to get it to save the Layer Files for each Group Layer in a separate folder.
So all Layer Files should end up in a separate folder like the Group Layer is called in my *.mxd.
I am not a coder and was already happy with the script I found but it would be great if somebody can help me with extending this script.
This is the script I was using:
import arcpy
mxd
= arcpy.mapping.MapDocument("CURRENT")
for lyr in arcpy.mapping.ListLayers(mxd😞
lyr
.saveACopy(lyr.name + ".lyr")
Thank you for your help.
Pierre
Tags (3)
OwenEarley
Occasional Contributor III
If you are doing this from the ArcMap Python window the following code should work:
import os
basepath = r'G:\xTemp\MapLayers'
mxd = arcpy.mapping.MapDocument("CURRENT")
for lyr in arcpy.mapping.ListLayers(mxd):
     if lyr.isGroupLayer == True:
          grpPath = os.path.join(basepath, str(lyr))
          if not os.path.exists(grpPath):
               os.makedirs(grpPath)
     else:
          fn = os.path.join(basepath, str(lyr) + ".lyr")
          lyr.saveACopy(fn)
          print "Saved: " + fn
Just change the basepath to the output directory.
DanPatterson_Retired
I think you have to go back to layer properties within arcpy itself.  There are some code samples there that shows how to save layers with different names and saving locations.  You can modify a workflow based upon these values.
OwenEarley
import os
     else:
          lyr.saveACopy(fn)
PierreKurth
Thank you I appreciate your help.
I tried this from the ArcMap Python window:
import os
basepath = r'N:\Temp\layerstyle'
             else:
                 lyr.saveACopy(fn)
Unfortunately it came back with an error message saying:
Parsing error SyntaxError : invalid syntax (line 6)
I am not a Python coder so any help would be great.
Thank you.
​from the else statement onward it is indented too much, see the source example provided
PierreKurth
The script is working now. Thank you very much it saved me a lot of time.
SepheFox
Whoops! Replied at the same time again!
SepheFox
Pierre, try replacing line six with          grpPath = os.path.join(basepath, lyr)
​and line ten with
fn = os.path.join(basepath, lyr + ".lyr")
SepheFox
Hey pierre, can you mark this question as answered? This will help other people with the same problem find the answer. thanks!
