Remove Layers
6510
16
04-12-2015 02:59 AM
Yaron_YosefCohen
Occasional Contributor II
Hi  everyone,
i have mxd with 85 layers and i try to remove layers (with arcpy) that don't exist in the current data frame. i using this code:
import arcpy,os,sys,string
import arcpy.mapping
from arcpy import env
env.workspace = r"C:\Project"
for mxdname in arcpy.ListFiles('*.mxd'):
     print mxdname
     mxd = arcpy.mapping.MapDocument(r"C:\Project\\" + mxdname)
     df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0]
     for lyr in arcpy.mapping.ListLayers(mxd,"",df):
          if lyr in df.extent == False:
               arcpy.mapping.RemoveLayer(df, lyr)
               print 'RemoveLayer'
     mxd.save()
del  mxd
but i get en error:
Project.mxd
  File "C:/yaron/shonot/software/gis/tools/YARON_SCRIPTS/aaaaaaaaaaaaaa.py", line 15, in <module>
TypeError: argument of type 'Extent' is not iterable
i don't know why my code doesn't work.
Thanks for any help.
Luke_Pinner
MVP Regular Contributor
The 'overlaps' method must return False if the dataframe extent is completely within/completely contains the layer extent. Try the 'disjoint' method instead. See the documentation - http://resources.arcgis.com/en/help/main/10.2/index.html#//018z00000072000000
Something like:
        print mxdname
        mxd = arcpy.mapping.MapDocument(os.path.join(env.workspace, mxdname))
        for lyr in arcpy.mapping.ListLayers(mxd, "" ,df):
              if df.extent.disjoint(lyr.getExtent()):
                  print lyr
        mxd.save()
    del  mxd
DanPatterson_Retired
extent is definitely not iterable... you should read up on the class objects before attempting them, there are functions in there that you can use to decide whether two geometries intersect and/or one contains the other etc.  In your case, I suspect that you need the extent of the lyr, then you need to decide which of the options that you wish to use and of course, whether the files is in the same projection as the other extent object.  Have a think, then propose your options before assessing code options.
Luke_Pinner
Extent objects support a 'overlaps' method
Try something like:
if not df.extent.overlaps(lyr.getExtent()) :
etc...
Sorry about the lack of formatting and links, the GeoNet mobile site is terrible.
Yaron_YosefCohen
i try  this:
     print mxdname
          if not df.extent.overlaps(lyr.getExtent()):
               print lyr
     mxd.save()
del  mxd
but actually arcpy remove also layers that have been halfly in the data frame
look at some of the other options in the link I sent you...surely you can figure out one that works or send the files to Luke for testing
Yaron_YosefCohen
i ask a question because i new in all that python stuff, if you noticed that. If you think that my questions are not clever enough please don't  answered them. your last answer are very sarcastic and I was very offended from you.
Then next time it would be best to try and articulate what you have tried.  All the information for testing is contained in the first link...you chose to grab a code snippet and hope it worked...that is not how you garner help, you have to make some effort.  I apologize if I offended you, but your questions and responses often don't show any attempt at research but seem to be geared to getting an immediate solution.
So did you try
  • contains
  • crosses
  • overlaps
  • within
  • touches
  • equals
  • disjoint
in place of Luke's suggestion...you are the only one that can answer that
XanderBakker
Esri Esteemed Contributor
Checking intersects or overlaps of extents does no guarantee that a layer has features within the current data frame extent.
I am wondering why you want to remove these layers? It because they are showing up in the legend or so?
Yaron_YosefCohen
no, i want to remove them automatically because they located out of the data frame. i mean the layers has coordinate system like the data frame but in specific area in there several layers and not all the the layers. so instead remove the unseen layers i try to build code that will do it.
Yaron_YosefCohen
i do read it ,but didn't understand - that the reason i join this forum.
