Passing argument to .on event
2427
04-17-2015 05:16 AM
CharlesGant
New Contributor III
I have a function that accepts a variable as an argument, within that function I have a .on event.  On the first run it works just fine, however when I call the function after the initial load with a different argument, it fails just before the .on event.  I tried using the data method in the .on documentation but that didn't work either.  Below is the code.  I'm passing the argument from a JQuery slider.  I know the new value is being passed to the function via my multitude of console print statements.  Anyone know what is going on?
    var csv360min;
    var csv360mintextLayer;
    function csv360minfunc(VALUE) {
    console.log("HERE");
    console.log(VALUE);
    csv360min = new CSVLayer("symGSPHydroViewer/data/360query.csv",{id:"csv360min",refreshInterval: .50});
    csv360mintextLayer = new GraphicsLayer({refreshInterval: .50});
    console.log(VALUE);
    csv360min.on("update-end", function(results){
        console.log(VALUE);
        csv360mintextLayer.clear();
        console.log("360HERE");
        arrayUtils.forEach(results.target.graphics, function(feature, index){
            var lid =  feature.attributes.lid;
            var name =  feature.attributes.name;
            var value = feature.attributes.value;
            if (value >= VALUE) {
            var ffg = feature.attributes.ffg;
            var ratio = feature.attributes.ratio;
            var validtime = feature.attributes.obstime;
            var attr = {"Location ID":lid.bold(),"Location Name":name,"Obs Value":value.bold(),"6 Hour FFG":ffg,"Ratio of FFG":ratio.bold() + "%","Obs             Valid Time":validtime};
            var geom = feature.geometry;
            var displayText = feature.attributes.value;
            var displayTextRatio = feature.attributes.ratio;
            returnedvalues = ratioColor(displayTextRatio);
            coloralt = returnedvalues[0];
            FontSize = returnedvalues[1];
            HaloColor = returnedvalues[2];
            var Halofont = new Font(FontSize,Font.STYLE_NORMAL, Font.VARIANT_NORMAL,Font.WEIGHT_BOLDER,"Helvetica");
            var textSymbolSouth = new TextSymbol(displayText,Halofont,new Color(HaloColor));
            textSymbolSouth.setOffset(0,-1);
            var textSymbolNorth = new TextSymbol(displayText,Halofont,new Color(HaloColor));
            textSymbolNorth.setOffset(0,1);
            var textSymbolEast = new TextSymbol(displayText,Halofont,new Color(HaloColor));
            textSymbolEast.setOffset(1,0);
            var textSymbolWest = new TextSymbol(displayText,Halofont,new Color(HaloColor));
            textSymbolWest.setOffset(-1,0);
            csv360mintextLayer.add(new Graphic(geom, textSymbolSouth, attr));
            csv360mintextLayer.add(new Graphic(geom, textSymbolNorth, attr));
            csv360mintextLayer.add(new Graphic(geom, textSymbolEast, attr));
            csv360mintextLayer.add(new Graphic(geom, textSymbolWest, attr));
            var font = new Font(FontSize,Font.STYLE_NORMAL, Font.VARIANT_NORMAL,Font.WEIGHT_BOLD,"Helvetica");
            var textSymbol = new TextSymbol(displayText,font,new Color(coloralt));
            csv360mintextLayer.add(new Graphic(geom, textSymbol, attr));
        var infoTemplate = new InfoTemplate("Attributes", "${*}");
        csv360mintextLayer.setInfoTemplate(infoTemplate);
    var blank = new Color([0, 0, 0, 0]); // hex is #ff4500
    var marker = new SimpleMarkerSymbol("solid", 0, null, blank);
    var renderer = new SimpleRenderer(marker);
    csv360min.setRenderer(renderer);
    map.addLayer(csv360min);
    map.addLayer(csv360mintextLayer);
    csv360min.hide();
    csv360mintextLayer.hide();
    csv360minfunc(0);
$(function() {
    $( "#slider" ).slider({
    value:0,
    min: 0,
    max: 1,
    step: 0.25,
    slide: function( event, ui ) {
    //console.log("FILTERVALUE: " + ui.value);
    var FILTERVALUE = ui.value;
    if (FILTERVALUE == 0.00){LABEL = 'Showing Precip > 0.00"';}
    if (FILTERVALUE == 0.25){LABEL = 'Showing Precip > 0.25"';}
    if (FILTERVALUE == 0.50){LABEL = 'Showing Precip > 0.50"';}
    if (FILTERVALUE == 0.75){LABEL = 'Showing Precip > 0.75"';}
    if (FILTERVALUE == 1.00){LABEL = 'Showing Precip > 1.00"';}
    //console.log("LABEL: " + LABEL);
    $("#label").html(LABEL);
    csv360minfunc(FILTERVALUE);
