add layer satellite map.
4077
5
04-18-2015 10:05 AM
lasinh
New Contributor III
How to add layer satellite in to my Map! thank you!!
YousefQuran
map = new Map("map", {
        basemap: "satellite",
        center: [-105.255, 40.022],
        zoom: 13
OwenEarley
Occasional Contributor III
See this sample - Create a map | ArcGIS API for JavaScript
As Yusuf Ali has already mentioned use the "satellite" basemap when creating the map (instead of the topo one that is used in the sample).
lasinh
New Contributor III
i have my  basemap, i want add layer satellite above the basemap
OwenEarley
The map object only supports displaying a single basemap layer at any time so you would need to add a layer to your map. To do this just use one of these:
Replace the URL with the endpoint of your satellite imagery source.
YousefQuran
    url:"http://services.arcgisonline.com/arcgis/rest/services/ESRI_Imagery_World_2D/MapServer/0
Add this Feature Layer to the map, but I do not know if it will works fine or not ... 'How to add Satellite above your basemap?', anyways try it!
