Add shapefile to map?
4387
5
04-20-2015 07:28 AM
JerryGarcia
Occasional Contributor II
How would you add a shapefile to the map using the JS API?  Thanks!
SamuelTompsett
Hello Jerry,
Here is the documentation and sample.
Add shapefile | ArcGIS API for JavaScript
Sam
JerryGarcia
I am not using the Portal.  Is there another way?  Thanks!
KellyHutchins
Esri Frequent Contributor
You don't need to be using portal to use the sample that Samuel linked to above - it just uses esriRequest to add the shapefile using the Portal REST API.
AlicePence
This way uses Leaflet calvinmetcalf/leaflet.shapefile · GitHub
Or you can try using Simple DynamicMapLayer | Esri Leaflet
--> with the last one, you don't need Portal.
SteveCole
I think this question comes up periodically. Here's a discussion from back in January which might help you:
How to add a shapefile without ArcGIS Online
