Tutorial for reading shapefiles in IOS App written in Swift
5179
04-20-2015 10:05 PM
AssetSarsengaliyev
I am new in ArcGIS and I don't know Obj-C. I am familiar with Swift, may be someone has a tutorial or example of a simple application to read a shapefile?
MichaelDavis3
Occasional Contributor III
The iOS version of the runtime SDK doesn't support shapefiles at this time.  This is supposed to be supported in the next version.
AssetSarsengaliyev
Thanks, Michael! Is there any way to read them? May be converting them to another format or adding all files into one gdb file?
MichaelDavis3
You can add them to a file geodatabase and then export them to a runtime geodatabase in ArcGIS using the "Create Runtime Content" tool.  This will create a read-only database and you can load the feature layers up in the mapView of your app.
