About attachments in flex viewer
6851
36
04-21-2015 11:04 AM
EvelynHernandez
Occasional Contributor III
I am developing an app that needs to add an attachment (pdf file) and save it in the arcgis db. Anyone knows how to do that?
My rest service has the attachment value in True, but idk why this code doesnt do it.
This is part of my code:
       myPropLayer.url = "myfeaturelayerurl";
myPropLayer.id = "NewEtaFeature";
  myPropLayer.addAttachment(1,byteArrayToProcess,"ElemetopPDF","pdf",new AsyncResponder(resultado,malresultado));
function resultado():void{
Alert.show("saved");
function malresultado():void{
Alert.show("not saved");
Mensaje editado por: Evelyn Hernandez. new Question about attachments
NigelDsouza
Hi Evelyn,
I got it. All you have to do is change this line of code
  function onResult(event:Object, token:Object=null):void
to
  function onResult(event:Array, token:Object=null):void
then you will directly get the url like this
       var url:String = event[0].url;
Try this and let me know.
Regards,
Nigel.
NigelDsouza
Hi Evelyn,
Your need to provide a valid objectid when you add attachments.
What error are your getting?
Also your resultado() and malresultado() methods need to have events passed as parameter which seems to be missing.
Regards,
Nigel.
EvelynHernandez
Do u have any example where u  do that ?
It will be useful  for me
Thanks!!
NigelDsouza
Hi Evelyn,
Just correct your code with the following and see if it works.
resultado(event:AttachmentEvent) and malresultado(fault:FaultEvent).
Regards,
Nigel.
EvelynHernandez
It doesnt work.
Do u have any complete example using that? I already read the sample in the developers webpage but idk why it doesnt work for me. Im not using the attachment inspector object.
EvelynHernandez
I need some help, im stuck on this.
I have to save a pdf file or image file in the arcgis db and idk how to do it through a widget. Theres no code example to try and seems nobody has done yet.
I have been trying with the attch inspector but it doesnt work. Anyone can give any example ?
Thanks for ur help.
I have this code but it doesnt work.
public function savePDF(byteArr:ByteArray):void
  var myfeaturelayer:FeatureLayer = new FeatureLayer;
  myfeaturelayer.url = "http:...../PMGD/FeatureServer/8";
  myfeaturelayer.id = "NewEtaFeature";
  myfeaturelayer.addAttachment(1,byteArr,"ElementoPDF", null,new AsyncResponder(resultado,malresultado));
  function resultado(event:AttachmentEvent):void{
  function malresultado(fault:FaultEvent):void{
NigelDsouza
When you debug this code what error do you get? Also check if your feature service has attachments enabled.
EvelynHernandez
i cannot debug my app, so when i execute the code i dont get any responde (not true or false)
NigelDsouza
Everything seems to be fine with the code you have written. you can also check the "layer details" property of
the feature layer to check whether attachments have been enabled on your featurelayer.
var layerDetails:LayerDetails = myfeaturelayer.layerDetails
if(layerDetails.hasAttachments)
       Alert.show("attachments enabled");
      savePDF(byteArr);
else
     Alert.show("Please enable attachments");
One more thing is, you could try passing the "content type" as a parameter instead of passing null..
  myfeaturelayer.addAttachment(1,byteArr,"ElementoPDF", "pdf",new AsyncResponder(resultado,malresultado));
And like i said earlier you need to pass a valid object_id.
And here's a small tip for to get your debugger working.
Assuming that you are working with flash builder it is necessary that the debugger version installed is the same as the version of flash player in your browser.
  1. First check the version of flash player running your browser. Navigate to the following link to check the version Flash Player Help
          if it is an outdated version I recommend you update it.
2. Once you've got your flash player version updated/installed navigate to the following link to download the debugger
     Adobe Flash Player - Downloads
Select the appropriate debugger and click install.
3. Then insert some breakpoints,run your app in debug mode and i think your off..
Actually its really hard to suggest any solution cause your code seems fine... i guess through a debug session you might be able to track some errors..or maybe some section of code that isnt getting called.. hence the expected output is void.
Hope this helps.. do get back,...
Regards,
Nigel.
EvelynHernandez
The code that u send me doesnt do anything, but in my rest srv i have the has attachment in true.
Im downloading the debugger.
And i also tried putting the "PDF" in the content type but still doesnt work.
Idk what more i should do...
