ArcGIS Viewer for Flex - display level of a clustered feauture layer
3004
04-23-2015 12:11 AM
ThomasSteudel1
presently i am working on a map project and have a question regarding the displaylevel of a clustered feature. I am relatively new to working with the config.xml (b4 i used the Viewer for Flex GUI.
Background:
My source code from my config.xml:
<layer type="feature" label="Akzeptanzpartner der Ehrenamtskarte" url="http://a-gis1:6080/ArcGIS/rest/services/Ehrenamt/MapServer/0" popupconfig="popups/PopUp_3.xml" mode="onDemand" visible="true">
            <clustering mingraphiccount="0" sizeinpixels="80" displaylevels="8,9,10">
            <clustersymbol type="flare"
                 alphas="0.6,0.8,1"
                 colors="0x00CC66,0x00CC33,0x00CC00"
                 flaremaxcount = "10"
                 size="30"
                 sizes = "30,60,90"
                 textsize="18"
                 textcolor="0x000000"
                 bordercolor="0xb28f00"
                 weights="10,100,9999"
            </clustering>
            </layer>
Question:
Question: I would like to configure the map in that way, that the clustering symbology will dissapear when i zoom into the map and the original unclustered points will appear within the map. Furthermore i would like to make the following layer "unvisible" when i first zoom in:
<!-- Layer Landkreisgebiet mit weißer Füllfarbe -->
            <layer type="feature" label="Landkreisgebiet" url="http://a-gis1:6080/arcgis/rest/services/Gemeindeflaeche/MapServer/0"           mode="onDemand" alpha="0.7" visible="true"/>
I found the layer tag "displaylayers" within the layer tag documentation file. But i think it is not working with features or?
Does anyone have an idea or a tipp how to solve my problem?
Thanks in advise and best regards,
Thomas
RobertScheitlin__GISP
Thomas,
   Take a look at the maxScale and minScale properties
Flex Layer properties
ThomasSteudel1
Hi Robert,
thank you for the link, but i think this source code is not related to the config.xml. What i want to do ist to define the min and max visible scale for a layer within the config.xml.
To change the java code i would need to modify the swf file or? How can i decompile/compile them? Only with adobe programs? Or would netbeans also work?
Kind regards and thank you in advice,
Thomas
Thomas,
  Setting the minscale and maxscale property on the layer in the main config.xml is the route you want to go.
ArcGIS Viewer for Flex - Layer tag overview
