Zoom to Geometry
4298
04-27-2015 09:06 PM
RoshnaDsouza
-(void)zoomToGeometry:(AGSGeometry*)geometry withPadding:(CGFloat)padding animated:(BOOL)animated; doesn't zoom to geometry when the map is rotated , it works fine when the map rotation angle is 0.
Tags (1)
GagandeepSingh
Occasional Contributor II
Hi Roshna Dsouza​,
I just tried it and it works for me. Can you share your code or explain what you are trying to do?
Gagan
RoshnaDsouza
I have to check if the geometry is zoomed to a particular resolution It should be visible to the user/
This code below works perfectly fine when maps rotating angle is 0. but when rotating angle is other than 0 ,
[self.mapView  zoomToGeometry:[self.editLayerManager geometry] withPadding:[defaultScale floatValue] animated:YES];
doesn't zoom to exact geometry with padding.
    AGSMutableEnvelope *visibleAreaEnvelope = [self.mapView.visibleArea.envelope mutableCopy];
    float zoomFactor = [levelScale doubleValue]/self.mapView.resolution;
    [visibleAreaEnvelope centerAtPoint:[self.editLayerManager zoomToGeometryCenter]];
    [visibleAreaEnvelope expandByFactor:zoomFactor];
    if (![visibleAreaEnvelope containsEnvelope:[self.editLayerManager geometryEnvelope]]) {
    } else {
        [self.mapView zoomToResolution:[levelScale doubleValue] withCenterPoint:[self.editLayerManager zoomToGeometryCenter] animated:YES];
GagandeepSingh
Can you provide a demo project as a way to reproduce the issue? It will help us in debugging the problem, if there is one.
