Drawing (*connecting) points to nearest polyline
5782
04-29-2015 09:21 AM
AlicePence
Occasional Contributor II
We have a bunch of points (water meters) and would like to see if there is a way to connect to the closest polyline (water lines) by building a script to have the points automatically connect to the nearest polyline (or a geoprocessing tool?)
Thanks!
SepheFox
SepheFox
Hi Alice, the ET geowizards add-in (ArcGIS tools add-ons and extensions from ET SpatialTechniques ) has a great tool called perpendiculars to polylines which does exactly that. The free version has limited use, but it might be worth your while to buy the license.
SepheFox
Oh, here you go. I found a free script that does just this: http://www.arcgis.com/home/item.html?id=0a4892bd754146e48b87de2352cdf64d
DarrenWiens2
MVP Honored Contributor
Thanks for pointing out this tool, Sephe (I wasn't aware of it). It solves most of the problem, but not the case where the point is not perpendicular to the line (see below), although that can be handled through other means. It's much easier to connect points to end vertices than to the line geometry itself. The script you linked to promises to do both cases, but I haven't tried it.
